Page 7 of 7 FirstFirst ... 567
Results 91 to 104 of 104
Thread: 1J Gurus - spark plug advice
  1. #91
    left handed lion tamer 1st year Apprentice 1.5jzmx83's Avatar
    Apr 2008
    victoria
    Default Re: 1J Gurus - spark plug advice
    hey all just got a quick question.. what type of plug do u think i will need to run???.
    here is my set up incase it helps im running ls1 coil packs.. motor is 1.5jz with 272cams to4r ect ect.... so anyway going to be running between 25-30psi now the question what type of plugs and what gap???. let me know what u all think cheers
  2. #92
    West Australia
    .6 gap
    BKR6E-P
  3. #93
    Forum Sponsor Conversion King
    What dwell time are you running?
    And don't put 6's in it as they are too hot for that setup, id go 7's if not 8's.
    .6 gap won't be nice when its off boost, try .8 to start with and adjust dwell time from there.
    linden
  4. #94
    Linden, what's your take on suitable dwell time for individual Bosch HEC-15 coils with Microtech, is there a limit to what can be run, or potential to damage the coils/ignition drivers? I've never experimented with mine, still set to whatever the manufacturer programmed for a "stock" 1JZ ignition system.
  5. #95
    Apr 2008
    victoria
    linden
    i havnt set it yet i guess turner will do that unless its easy enough to do myself????.
    so i should get a set of bkr7e or bkr8e's??? what the difference between bkr7e-11 or bkr7e-p ???? does the p stand for platinum??? and does the 11 stand for 1.1mm gap???
  6. #96
    -Street Drag Machine- Grease Monkey renxun's Avatar
    Jan 2007
    Sabah
    Quote Originally Posted by 131OWN
    I'm running BKR7E11 with std gap (1.1mm) with my t04z, 24psi, PULP, 1.5j, it revs clean, I must say the Bosch coils are crackers!!!
    what do you mean Bosch coils are crackers? they crack often? what PULP means?
    im using the Z too. but on a 1jz ran on stand 1.1 gap before. but experience spark blown out at 27psi.... keep lowering down the gap to 0.8 then only i can go slightly above 2 bar on scramble.
    btw im running on denso IK24 iridium
    Drift Drift Drift and drift untill getting high fever...
  7. #97
    Phil, it depends on a few things.
    Plug choice + gap, RPM, boost etc
    generally its set anywhere from 2.4-3ms depending on the ecu/igniter type.
    certain ecu's (good ones) will allow you to adjust dwell dependant on revs, so you can add more dwell at the point of peak torque to counter misfires but then decrease the dwell as the revs rise to allow them more of a cool down period between cycles (117/second @7000rpm on a waste spark setup)
    Ill put you onto a good tuner when your in sydney next and he can talk your ear off about all aspects of tuning, he reminds me of "donkey" and i feel like shrek.
    1jzmx83, pretty much answered your own questions, if its a road car id go BKR7E's, and if its goin to a circuit/drift day id probly chuck in a set of BKR8E's if your planning on keeping it at WOT for extended periods with high boost. both sets would need to be gapped at roughly .8mm.
    not sure on who your tuner is so i don't know wether they check everything first or just tune what you gave them and leave you to sort out the problems later.
    Linden
  8. #98
    Apr 2008
    victoria
    thanks linden...
    yeah i havnt chosen a tuner yet still trying to find out who 2 trust lol
    anyone have any idea's???? im located in melbourne cheers
    also car is running a heltech platinum sports 2000... dunno just though i would let u know as maybe some tuners dont like them...
    o yeah and it will be used for drift
  9. #99
    So Linden, can I read into this that the only significant downside of running longer dwell time (within reason) is overheating of the coils? Or am I over-simplifying it somewhat?
  10. #100
    oversimplifying it abit but id have to write an essay to explain it in more detail.
    Come to the big smoke and we can talk about it over a coffee or 10.
  11. #101
    Sure dude, i'm on my way, see you in 3 hours......... (nawt )
  12. #102
    Junior Member Backyard Mechanic gwilmarlio's Avatar
    time to dig this one up
    in the prosses of tuning my 1J going to put some new plugs in BKR7E's in coppers gaped to .7
    I am trying to get the boost to 22-23psi can run 19 without blow out 20 starts to miss
    I need to heat shrink my coils to will do this in the next few days
    what I want to know is if any one has some info on will new coils and a HKS DLI give me a good spark at a larger gap at 22-23psi ?
    also at this boost should I be looking at BKR8 ?
    1990 JZA70 R 12.959sec at 112.78 mph Kwinana Motorplex
    1J torsen smashing machine
    TR44 Highflow single (366whp at 17psi)
    1988 GA70 SOLD and will be missed
  13. #103
    You are better off getting some brand new coils . Combined with a DLI you can run a gap up to 0.9 without an issue running 22+psi .
    Ultimately New coils + DLI = Spark to run 30psi
    11.72 @ 116.7mph = Quickest Stock Turbo Jzz30 series Soarer And 1st into the 11's WOOOT!!!
    Still going good
  14. #104
    that is the plan I just needed to know how well it will work I am going to start looking around for new coils any one got a start for good prices ?
    heat srunk my old coils today and put some new BKR7E copper plugs in gaped to .7 will give it a run tomorow
  1. Wasted Sparks VS Sequential Spark
    Last Post: 08-01-2018, 12:19 AM
  2. Oil in spark plug chamber 3sfe
    By dundee230966 in forum Tech and Conversions
    Last Post: 10-04-2007, 12:46 AM
  3. 4AGE Spark Plug Cover
    By AE92 Rolla 4A-GTE in forum Tech and Conversions
    Last Post: 29-10-2006, 06:13 PM
  4. Spark Plug Question
    Last Post: 22-05-2006, 08:09 PM
