some more photos of a 4K-E manifold for everyone![]()
so here's pics from my page.. http://www.materials.unsw.edu.au/~sford/7ke4ke.html
7KE has 10" runner, 4KE has 20" runner (valve to plenum)
7KE has 50mm TB (and variable TPS), 4KE has 40mm TB (and switch type TPS)
7KE has 195cc injectors (skinny type), 4KE has 145cc injectors (normal toyota type)
That 4K one could almost only be rivalled by the 'efi 202' unit for length
Were they actually trying to get some kind of low down urge from the 4K hey?![]()
actually, it is very similar to the 2TG, the EFI 202, the XF4.1....
basically, at the time, the current technology was to have long runners to try and promotr torque down low... but this only helps really if you have small ports to help increase the velocity..
both the 4K and 7K have 30mm internal diameter runners.. same as the large port heads, which i think is too big (perhaps) for a street 4K anyway..
but yeah.. it was in line with current trends at the time (early 80's)
i used the 7K due to time constraints, but the 4K one positions the plenum better for turbo apps![]()
What cars do you get the EFI manifoilds off? Are they out of the vans or something? and are there hard to get and wire up?
* 73 KE26 - x4 Brown Wagz
* 73 KE20 NOW 3T-TE
* 84 KE70 Panno
* MX83 LS1 Track Car
Out of Toyota Liteace/TownaceOriginally Posted by Hurricane
Hard to get - Yes, unless you buy the whole motor from i have found? ($$$).
If you buy the whole motor, the 7KE will require alot of modifications to fit in a KE Corolla due to the extra length of the motor (stroke) - I'm sure Old Corolla's could confirm exactly what needs to be done!
Best to fit the injection to a 3/4/5K in a KE Corolla
ROB
You can also import them from NZ as they came out in the Starlets. The good RWD ones which we did not get over here![]()
I forgot about the KP Starlets!Originally Posted by Hokey
ROB
Jap spec only, not NZ new. Realistically if you are going to mod the motor then custom is a definite option considering what people try to charge for the factory setups.Originally Posted by Hokey
Callum
US 1981-1983 KP61 starlet also got the 4KE injection (which is where mine is from)
the 7KE is from the Townace SBV around 2000 model.
both 7KE and 4KE systems seem to go for between $200-400 depending on completeness and extras..
i used the 7KE initially cos it has 50mm TB instead of 40mm, and it had a variable TPS instead of switch, but the 7KE has the thinner denso style injectors making larger ones harder to source.
the 4KE uses normal style injectors, so almost all other toyota injectors go straight in... i would probablyuse 4KE with a larger TB fpor a forced induction motor...
both types, when used with a MEgasquirt make for a very cheap injection system (use either electronic dizzy from 4KE/5K, or points dizzy with Jaycar HEI)..
any questions, i am happy to answer.. i osold my 4KE gear, but still have 7KE gear installed on car..
Cya, Stewart
ive recently purchased a 4KE injection setup, complete apart from computer.
stu how much would i roughly be looking at for a megasquirt computer?
is it tru u can run the AC delco computers from camiras ect etc?
any help would be much appriciated.
cheers scott
74' KE26 4dr Wagon, the daily, aka tha sak wagz.
The sump hits the crossmember and unfortunatly the block skirt is 20 mm wider than 4 or 5 k so the earlyer sumps dont fit . The engine mounts fit on but due to the block being wider it doesnt bolt in 100% nicely.
A bit of panelbeating to the sump seams to work ok
Dave
here is the 4KE manifold i just purchased
all i need is a computer?
any ideas what i can run successfuly?
cheers scott
I read an article about delco computers in Perth streetcar..i think it was called, they aound pretty good and not too hard to install, i'll have a look for the mag and write some of it up here if you want?
did you get that from madrolla68? he had one for sale on rollaclub...i was thinking of buying that.
Signatures must be no more than 5 lines of text at 1024x768. Advertising is not allowed in signatures.
hey cam rush, that would be much appriciated if you could find me that article, any help will be awesum.
no it aint madrollas setup i bought it off ebay today![]()
cheers scott
