o.k,
Seem to have the suspension sorted now,
brought a full set of BC racing s13 coilovers, the botoom brackets are made of steel, sooo
I will cut the s13 brackets of so im left with a steel threaded tube, so no longer need to have one made from scratch.
The bc bracket is very very close to sliding over the std strut tube, so i will take it down to the exaust shop and get it expanded about 1mm so it is a very close fit, and just hammer it on.
The rears maybe slghtly more tricky, the bottom EYE hole on the s13 shock is larger than the toyota one, so ill either get a bush that fits,get one turned up, or turn up a sleve that will fit on the bottom shock mount(once heated) and then will mount the s13 coil on there, the top is also tricky, i will prolly end up custom making a upper mount with some 4" tubing and drill it to suit the s13 bolt pattern.
fronts will be done like this, but will make it tidyer.
http://www.the510realm.com/PNphpBB2-...ic-t-4346.html
The botoom mount will also need to be re inforced so it can handle the spring preload.
