Thanks for the post... That will be good info for those MA61 owners...
Cheers.
 MA61 Part Numbers & General Infomation
				MA61 Part Numbers & General Information
BUSHES
Noltec: 02 9980 9777
http://www.noltecsuspension.com.au/
MA61 Noltec Urethane bushes
NOTE: Prices are over the phone quotes from Noltec Direct, and are JUST A GUIDE
Control Arm Inner (FRONT).........N51665 $34+ tax
Radius Arm (FRONT).................N81664 $37+ tax
Control Arm Inner (REAR)...........N61666 $70+ tax
Control Arm Outer (REAR)..........N61667 $82+ tax
SuperPro Urethane Bushes:
http://www.bac.com.au/
NOTE various prices available, depends who you speak to. below are JUST A GUIDE
Front Control Arm Lower - Inner Bush..........SPF0509K $24.5 Use original shell 2B,2T
Front Strut Bar To Chassis Mount...............SPF0307K $25.5 4B
Front Sway Bar Link Bush Kit.....................SPF0903K $13.5 8B
Front Sway Bar Mount To Chassis Bush......SPF1450K $10 Measure bar dia 12-30mm available 2B
Rear Control Arm - Inner Bush.....................SPF1213K $55 [IRS] 8B,4T
Rear Shock Absorber - Lower Bush.............SPF2178-16K $9 2B
Rear Shock Absorber - Upper Bush.............SPF2755SK $10 4B
Rear Sway Bar Link Lower Bush.................SPF0280K $15 4B,2T
Rear Sway Bar Link Upper Bush.................SPF0903-4K $9 4B
Rear Diff X-Member To Chassis Mount.........SPF2926K
Rear Cross-member To Chassis Mount........SPF1447K $115[Listed under Supra but assume is same as IRS Celica 4B,2T
Nolathane
http://www.redranger.com.au/
Rear Sway Bar Mount to Chassis Bush.......#42330 $21**
**Needs slight modification of the swaybar bracket. Click here.
BRAKES
Rotors:
DBA...........MA61..........Z32/R32........R33 GTST........R33 GTR
Front...........#146............#909.............# 4963..............#4928
Rear............#717............#908.............# 908................#929
RDA...........MA61..........Z32/R32........R33 GTST........R33 GTR
Front
Rear...............................#908........... ..#908
Pads:
EBC Greenstuff
.............MA61..........Z32/R32........R33 GTST........R33 GTR
Front....DP2456
Rear .....DP457*
*Blackstuff
DRIVELINE
Auto to Manual conversion
For a list of compatible parts to use for this conversion, click here.
The Toyota Axel Database by the famous Norbie.
Wheel and Gearing Calculator where you can also find out what speedo gear drives you need to have an accurate speedo.
For a correct speedo with a 3.73 diff ratio with stock wheels (ie 195/70 R14 or 225/60 R14), you'll need an 11 start worm drive gear with a 32(11) driven gear.
Where to find second hand diff ratios.
SUSPENSION
RA60 strut install website with a bit of detailing of the differences between the RA60 strut and MA61 strut
Sway Bars
*Please note that the rear sway bar mounts on the crossmember are prone to breaking after upgrading your swaybar. I strongly recommend re-inforcing these brackets before you install some new sway bars. The stronger sway bars bend this bracket up and down over bumps and weakens it. They then eventually snap in half. Clicky
Addco:
Front: #ACO-375 : 28.575mm
Rear: #ACO-745 : 19.05mm
$298US Rabid Chimp
Whiteline:
Front: BTF-76 : 27mm : $213
Front: BTF-76Z : 27mm [Blade Adjustable]
Rear: BTR-21 : 19mm : $171
Rear: BTR-21Z :19mm [Blade Adjustable]
Strut Bars
935 Motorsports:
Front Adjustable Strut Bar US$149
Rear Adjustable Strut Bar US$149
Rear Adjustable Carbon Fiber Strut Bar US$175
MK2 celica supra front and rear stut braces thread!
Making custom strut bracethread
Adjustable Strut Tops
Noltec:
Camber/Caster Adj #N44027 $350
Kmac:
Camber/Caster Adj #761316K $400
Cusco:
Camber Adj US$229 [935 Motorsports]
King Springs
................Low............Std
Front......KTFL-31......KTFS-31
Rear.......KTRL-27......KTRS-27
Shocks
*This is an Excel file of all known shocks compatible with the MA61 chassis. Included are KONI part numbers and details.
Download Here
Rundown of front struts increasing stiffness.
KYB - GR2 (only girls use these)
Koni - Red (from what I've heard... stock-style replacement)
Tokico - HP (logical low-cost solution)
Koni - Yellow (just... hump my wallet please)
KYB - Select-a-Ride (What Joe runs in his race-car!)
KYB - AGX (the mr2 inserts spacered to work... lots of happy customers on these)
Rundown of rears, same gig.
KYB - GR2 (only wussie girls use these)
Koni - Red (from what I've heard, again)
Tokico - HP (eh... go gas-a-just or AGX)
KYB - Gas-a-Justs (easy to acquire and work gooood IMO)
Koni - Yellow (still humping my wallet? goood)
KYB - AGX (the focus rear's we've seen good luck outa, came in the groupbuy)"
KYB
Front: MR2 SW20 [Wes's Write-Up, externally adjustable]
#765016
Rear: Ford Focus 04 [Wes's Write-Up, externally adjustable]
#741067
--Please note that the above two shocks need some modifying to fit. Please follow the links above.
--These shocks are available through 935 Motorsports Here for US$325.
Front
#365076 - $168.18 +GST
Rear
#343042
KONI - Great read on KONI shocks here
Please note:
The 'Red' or 'Yellow' after the shock description denotes the shock absorber stiffness.
Yellows are stiffer than the Red shocks.
Please refer to here to check if the shocks in question are externally adjustable or just standard adjustable. Special thanks to Wilbo there.
Front: MR2 SW20 Rears. KONI Yellow#
#8641-1221 Sport
Rear: E36 M3 Rears. KONI Yellow
#8240-1115 Sport*
-This combination seems to be the best for a street/weekend race setup. 935 Perfomance have these for sale in the USA for AU$900 shipped.
#Gland nuts supplied are 1.5 thread. Required gland nut thread is 1.0 to suit xA6x strut. Koni part number for correct gland nuts is: 7325-01-0021, $40 the pair.
*You have to replace the lower 'eye' bushing in the shock with
SPF2178-16K from Superpro, to work with the MA61 suspension.
Front: xA6x Fronts. KONI Yellow (Fulcrum Suspension $600)
#86-1991 Sport*
Rear: xA6x Rears. KONI Reds [not in production?]
#28-1131 Sport*
*You can still buy the #86-1991 Here and the #30-1599 Here from Classic Garage in America.
Front: TOYOTA CELICA SUPRA 84/85. KONI Reds[listed on Whiteline website]
#86-2328 Sport
Rear: RAV4 KONI Reds
#30-1599 Sport
Rear: VB VP Commodore Reds
#80-2597
GABRIEL
Front
#G44939 (Note this is the wrong part number, although no one will admit it. You can get Delco (rebadged Gabriels) shocks off eBay from Ultracheapauto.com)
Rear
#81440
OTHER MANAFACTURE PART CODES
Mackay Rubber:
- New Pedal Rubbers - #A1281 $5ea Clutch and Brake only. No Auto Pedals
- Engine Mounts (rubber) - #A5196 - ~$80 a side (genuine is $160) (listed under MX73, no MA61 listing) ** $110 for the pair at Repco
- Gbox mount (rubber) - #A5197 (Don't know price) (listed under RA60/SA63/RA65, no MA61 listing)
Repco:
- MA61 Balljoint - TBJ314 - $48 each
5ME Belts:
- A/C - 13A0990 - $15.99
- Alt - 7PK0920 - $32.79
- P/S - 13A1420 - $19.99
NGK Plugs
- BPR6EY (5ME) - $26.34 (for 6)
- BCPR6ES (7MGTE)
- BCPR7ES (7MGTE, 1 heat range colder than stock)
Top Gun Leads - TG6032 (5ME) - $64.99
Camelot:
- MA61 Tie Rod Ends - TE-641R
Gates:
- Upper Radiator Hose for 5me to 5mge conversion - EF Falcon 1994 onwards - PN# 05-0917
VENDOR LINKS
RDA Brakes www.rdabrakes.com.au
DBA Brakes www.dba.com.au
Noltec Suspension www.noltecsuspension.com
Addco Suspension www.addco.net
Whiteline Suspension www.whiteline.com.au
SuperPro Bushes www.bac.com.au
Nolathane Bushes www.redranger.com.au
K-Mac Suspension www.k-mac.com.au
Cusco Suspension http://www.cusco.co.jp/english/e_cont.html
KYB Shocks www.kyb.com.au
Koni Shocks www.koni.com
King Springs www.kingsprings.com
Techno Toy Tuning www.technotoytuning.com
Rabid Chimp www.rabidchimp.com
935 Motorsports www.935motorsports.com
Import Bitz www.importbitz.com.au
Forcefed Performance www.forcedfedperformance.com.au
Castle Hill Toyota www.chtoyota.com.au
TOYOTA PART CODES
Clip Door Trim FJHJ6 (Clip that holds door cards on) .......................67771-22010 $1.15ea
Retnr RN 30 4# (Lower bush seat on the sway bar end link Fr) .........90948-02015 $1.50ea
Clip Molding FJ8309 (Plastic clip used to screw stuff into) ...............90189-05012 $1.25ea
Ring Lamp MS112 (Plastic Sphere clip for indicators) .....................81219-14040 $2.25ea
Rear Spring Lower Seat RH .................................................. .......48258-22041 $25ea
Rear Spring Lower Seat, LH......................................... .................48258-22050 $25ea
O Ring V292 (Oil filter bracket to block O-Ring, 7M-GTE).................90301-68005 $4.85ea
Rush Shift RN7808 (White Cap W5x Shifter)...................................33548-31010 $8.64ea
Seat MTM LVRLN46811 (Green Seat W5x Shifter)..........................33505-35020 $19.50ea
7M-GTE Accordian Hose .................................................. ..........17882-42012 $93.95
Oil Filter (All M series motors) .................................. ...................90915-YZZD2 $19.85
Grommet (4 brake lines where they go through side of engine bay)...90480-22210 $4.05ea
Longlife Coolant 4L (Toyota Red)...................................... ............08889-80086 $34.75ea
Hose (5M Lower Radiator Hose, EX Japan).................... ...............16572-41101 $16.25ea
Hose (7M Upper Radiator Hose)...................................... .............16571-42010 $16.25ea
Liner Clip RZN169 (Splash gaurd screw in clips)..............................90189-06220 $1.00ea
Hose MA70R (PCV hose to accordian pipe)...................................12264-42010 $25.25ea
W57/58 extension housing oil seal ............................................... 90311-38032 $19.36ea
Front grille clips (the little clips that break)......................................90467-12008 $1.85ea
Plug Manifold CM8301 (Diff filler plug).................................. ..........90341-18006 $5.80ea
Speedo Worm Drive Gear, 11 tooth............................................. ..33481-22020 $57.15ea
Speedo Driven Gear, 32(11) tooth............................................. ....33403-19255 $52.95ea
Washer, Plate (Sits under the axel shaft nut, clicky).......................90201-20329 $4.80ea
MA61, RA65, Rear carpet .................................................. ........ 58570-14231-20 (Black)
Head Lamp Protectors (Rubber strips)
Left hand side.............................................. .............................. 54126-14011 $128.oo
Right hand side.............................................. ............................ 54125-14011 $128.oo
Clips ( 4 per side )................................................. ........... .......... 90467-07023 $ ??
Final Gear set (Diff) - "F" crown & pinion
4.100:1... 41:10 teeth............................................. .... 41201-39575...
3.909:1... 43:11 teeth............................................. .... 41201-39585...
3.727:1... 41:11 teeth............................................. .... 41201-29298...
3.583:1... 43:12 teeth............................................. .....41201-39467...
Power Steering Rack Kit
P/S pump.............................................. .................... 04446-22010 $62.00ea
P/S rack master kit............................................... ...... 04445-24012 $158.00ea boots extra
#NOTE: Rack master kit includes the control valve overhaul kit
INTER-CHANGEABLES
Most xA6x Parts
MZ10 is almost identical to the MA61
MA70 1" Brake Booster and Master Cylinder
FZJ80 1" Braker master cylinder, direct bolt in (tbc)
MA61 Auto crossmembers are a perfect fit for fitting the A340E gearbox
MX73 LCA's are exactly the same.
CONVERSIONS, UPGRADES AND GUIDES
Ed's MS65 Front 5 Stud Hub Upgrade
Sam's RA65 Struts and Steering Arms Upgrade
Sam's GH Sigma LCA Install
Sam's Changing valve shims on a 7MGTE
Sam's Rear Parcel Shelf Guide
Sam's Front Strut Brace
Cruzida's xA6x Skyline Brake Upgrade
Michael's 5 Stud Conversion
Norbie's MA61 Suspension, Brake and Wheel Upgrade
Norbie's 6 speed conversion, V160
Andy's 7MGTE Conversion
Joorsh's 1JZ / 2JZ into MA61 / MZ10 Guide
Dave's R154 Install Write-up
James' Cruise Control Install Write-Up
James' How to build a Tacho Adapter
Tim's AU Falcon Thermo Fan Install
Rob's DIY Rear Spring Replacement Guide
Rob's DIY MA61 S13 Strut Tower Brace
Rob's 5ME Air Pump Removal
thomasbl: Problems With Installing a W5x shifter
Enchanter's 5ME to 5MGE Conversion Guide
Peter's How to, Tacho Booster
Bbaacchhyy's old 5 Stud conversion thread
OTHER RANDOM TECH LINKS
Rose jointing LCA's
Toyota gearbox ratios
Differences between xA6x rear swing arm mounts
Continued a couple posts down...
MA61 Part Numbers, Upgrades and General Infomation <--- Clicky Clicky
 Re: MA61 Part Numbers & General Infomation
Cheers.
				EBC Green fronts for MA61 - DP2456
SHE LIVES!
				Just a note, but I wouldn't be putting up that you can replace the 15/16th master cyl with a 7/8 one.
I think you'll find thats highly illegal.
Unless the 7/8th is a typo?
				Well done on the list. Thats going to be more than helpfull.
				First post passed 20000 characters, continued here...
Thanks to Cruzida, 7MA61, Viper, Stefan, ed_jza80, Joorsh, Norbie, Michael, Yian, Tim, Wilbo, Chris, James, thomasbl, Peter, GA61XX and anyone I’ve missed, without the info that they have provided somewhere on the forums this list couldn’t have happened.
This is just a list i have compiled of the infomation that i have gathered. Had it laying around for a little while and thought i'd better post it up. If the Mods think it should be in the FAQ's then by all means move it.
If anyone has any information or can fill in the gaps above (eg the pads and RDA rotors), let me know and I will enter it in above.
Sam
				Updated it a little bit. Still need all the other infomation missing. I spose i should hunt it down myself but i cant be bothered/don't have the time at the moment.
				I have the part numbers at home for EBC pads - MA61 rears and R33 GTSt fronts. I have Greenstuff up front but they only make Blackstuff for the rears. Anyway shoot me a PM to remind me and I'll give you the part numbers when I get home.
Norbie!
www.norbie.net
				Mackay Rubber makes new Pedal Rubbers
A1281 is the number. They aren't 100% tight like the factory ones, but useable none the less. $5 each for clutch and brake (nfi about auto)
Rear spring lower seats are 48258-22041 - about $25 a side.
Thats all I can offer from here.
				whoa! impressive stuff SamI will post rear main seal replacement part number, and other numbers for 5m
EDIT: Tim aka ZZT231 should take credit for the AU thermo fans I think, also it's James' not Jame's
better link for the cruise article: http://www.toymods.net/forums/showpo...&postcount=740
				Smalll radiator hose is available in the right size to slip over the bottom coil as an alternative... well, that's what a shop did to my springs years ago.Originally Posted by CrUZida
				Norbie, you have a PM
Thanks Cruz, thats still pretty good info there. Every little bit helps
Thanks Viper, looking forward to the part numbers.whoa! impressive stuff SamI will post rear main seal replacement part number, and other numbers for 5m
Yes, thats Tims. Silly me, im getting peoples names mixed up now. Never was good at names
And a big thanks to that link to the cruise control article.
And cheers Stefan aswell. Im sure some people will find that useful. I know i sure would if i had some radiator hose laying around and had perished lower seats.
				Can anyone confirm that this is the part number for MA61 camber/castor tops? I ask this because according to the Noltec catalogue:Originally Posted by Negative Boost
CELICA TA22,TA23 ‘70-77
Strut - top mount (Urethane- street) F 2 ■ N44027 1 Camber/caster adjustable
Strut - top mount (Solid-clubsport) F 2 ■ N44027S 1 Camber/caster adjustable
SHE LIVES!
				I can tell you that xA6x Celica strut top bolts are offset 60* compared to xA6x, xA4x & I asssume xA2x Celcia ones - so if the decription is correct, they won't suit your car.
There are also T3 tops to consider, but they don't work with stock upper hats (need coilovers). Or KMAC if you don't mind them being flimsy
				W5X Alloy Shifter Bushes
White Cap # 33548-31010
Green Seat #33505-35020
