courtesy of hen and takai posts.
S13
bottom of taper diameter : 17.96
top of taper diameter : 16.08
height of taper : 14.72
ratio : 1:7.83
MX62 - BJ314
bottom of taper diameter : 17.92
top of taper diameter : 15.85
height of taper : 16.71
ratio : 1:8.02
AE86,KE70,TA22,RA40,XT130 - BJ145
takai's figures
Model - Length - CT Dia
RA40 - 300mm - 12mm
TA22 - 300mm - 12mm
AE86 - 300mm - 12mm
KE7x - 300mm - 12mm
XT130 - 310mm - 12mm (RT132 too?)
MX73 - 304mm -12mm
MX62 - 365mm - 12mm
GE Sigma - 330mm - 12mm
S13 - 350mm - 14mm
hen's figures
Car - Length - Swaybar - Castor rod - CT ID - CT OD - CT Length - Balljoint
AE86 - - - -- 300 - 190 - 225 - - - - 12.4 - 16.5 - 59.5 - BJ145
RA60 - - - -- 300 - 180 - 225 - - - - 12.4 - 16.5 - 59.5 - BJ145
MX62 - - - -- 360 - 230 - 270 - - - - 12.4 - 16.5 - 59.5 - BJ314
GE Sigma - 330 - 220 - 250 - - - - 12.3 - 17.8 - 64.5 - BJ122
S13 - - - - -- 350 - 190 - 210/235 - 14.0 - 19.5 - 60.0 - BJ???
http://www.toymods.net/forums/showth...highlight=lcasThe BJ314 balljoint is a good fit in the S13 knuckles and this balljoint is found in many Toyota LCAs (MX62, MX73, MX83, JZX81, MA61 and more) so finding one which is the correct length would be great.
hen
also sigma GH LCA's installed into Ma61 by Negative boost
http://www.toymods.net/forums/showth...309#post278309
so, RA40, TA22, AE86, KE70 ETC... look like a good size to use but we just have to change the ball joints and redrill for caster/sway bar mounts.
**EDIT*
according to http://www.oem-products.com/f/PAJA%2...5-Edition1.pdf
MA61, SA63, MX32 - MX73, MZ/GZ10/11/12 are all BJ232's?
- will do a full write up and install without all the crap inbetween soon
