hey.
It sounds like maybe you have a head gasket problem. water maybe be going through the engine and out the exhaust.
How does the engine run when you are driving? rough idle? running hot? all these are BHG signs......
Another thing would be to do a visual inspectin of hoses and hose clamps and water pump. check with the engine running, if there is a hole in a hose then you should be able to see it coming out. It will also drop water onto your driveway.
As for the engine, check the for sale section. Alternativly toymods has some pretty good sponsors with engines and half cuts that should suit your needs!
