Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 61 to 75 of 115
Thread: The AW11 Brake Upgrade Thread
  1. #61
    Junior Member Grease Monkey dizzy's Avatar
    Default Re: The AW11 Brake Upgrade Thread
    Just a small qtn
    Upgrading 87 model NA brakes to later model SC brakes which Ive sourced for cheap.
    I have next to no knowledge about braking systems
    Is there anything I really need to know?
    Would I need to upgrade my brake master cylinder?
    Thanks!
  2. #62
    Quote Originally Posted by dizzy
    I still use my standard MC with my ST185 GT4 front brakes.
  3. #63
    Just a small qtn
    ummm, aren't they the same?
    if your 87 has the upgraded brakes, then they are the same as the S/C ones I thought. If your car is an Aus delivered car then it's definitely already got those brakes already.
  4. #64
    they are the same no difference between 86.9+ NA and SC brakes.. none at all.
  5. #65
    Thanks for info!
    To be specific, Its an import NOV 86 model that I have.
    My situation is that my rear discs seem to be damaged and Ive been offered a set of front and rear discs and calipers that came off an SC for 200 dollars and I thought it may need some other modificatoins to make it fit/work.And the discs on the set I'll be buying are abit larger in diametre?
    Will double check and compare on the weekend, otherwise, ill just get the rears replaced.
    Thanks
  6. #66
    Original Trendsetter Chief Engine Builder Harreh's Avatar
    Jul 2008
    Holy thread revival batman!
    Well from what I can tell DBA arent doing the brakes anymore, atleast not slotted.
    Cars got slotted on them already and I know I don't really need slotted but I'd like to keep them that way, so has anyone got some part numbers? I'd like to increase the disc diameter if possible. To my understanding RDA are still selling them
    AW11 Turbo build
    1UZ Soarer Turbo build
    Imitation is the most sincere form of flattery
  7. #67
    ive got a set of AE101 twin piston calipers with 265mm rotors all direct bolt onto an aw11 spare her i want to get rid of
  8. #68
    ASL? Backyard Mechanic thegreatestben's Avatar
    Feb 2007
    This thread has been real helpful doing the upgrades on my AW11,
    I thought I'd post up what I went with.
    Front:
    Celica ST185 Single piston calipers
    Celica ST185 Single piston Rotors redrilled to 4x100
    Rear:
    SW20 Late Model Calipers (22V)
    AW11 Front Rotors With 6mm spacers
    Master cylinder is a 1" unit from a Hilux. Part Number 32986545
    Pics:
  9. #69
    I cbf doing the measuring... can you tell me what to OD is on the spacers to fit inside the rotor like that?
  10. #70
    Feb 2007
    130mm, there's a raised edge inside the factory rotor so need to chamfer the edge.
  11. #71
    Beer anyone?? Domestic Engineer Just1n_mc's Avatar
    Quote Originally Posted by thegreatestben View Post
    Don't fancy making up a couple of more sets by chance? I'm sure some of us to lazy to make them ourselves would buy them off you for the rear upgrade.
  12. #72
    Feb 2007
    I have been asked If I can make some others but with the type of tools I have at my disposal it's not really worth it, I made them in the garage, each piece takes an hour to cut then an hour or two to machine cos we've only got a basic lathe up and running at the moment.
  13. #73
    Not trying to be a Carport Converter
    Jan 2009
    These "spacers" you guys are talking about, are these like the wheel spacers (that are illegal) or is this a bracket spacer? surely if its a hub kinda spacer the extra force the extenstion generates could damage the hubs/bearings etc?
  14. #74
    Feb 2007
    They go between the hub and the disk, mine are hub centric and the disk is still located as well.
    Unsure to the legality where you are, but here in NZ they are legal but would require cert, (but I don't think anyones gonna see them on my car )
  15. #75
    It sits behind the rotor rather than between the rotor and the wheel. No one would even know it is there, and can be engineered anyway.
    They are also only 6mm so not altering the weight balance onto the hub and bearing very much, not as much as low offset wheel for instance, as the extra mass is close to the centre of mass of the hub assembly.
    By The Witzl in forum FAQ
  2. xA6x, xZ1x, xX7x + others FRONT AND REAR Brake Upgrade
    By CrUZida in forum Tech and Conversions
    Last Post: 24-07-2018, 11:43 PM
  3. GX71/MX73 brake upgrade, the easy way...
    By Soarer21 in forum Tech and Conversions
    Last Post: 18-12-2005, 11:15 PM
  4. brake booster upgrade for 86
    By PDS86 in forum Tech and Conversions
    Last Post: 30-11-2005, 09:51 PM
