Results 1 to 10 of 10
Thread: 22 pin connector to 4agze ecu (female) where from?
    Apr 2009
    Default 22 pin connector to 4agze ecu (female) where from?
    can any one help?
    im looking for the 22 pin connector / plug to go into:
    ive tried wreckers and they tell me they just have the ecu themselves and chuck the looms out!
    Apr 2008
    Default Re: 22 pin connector to 4agze ecu (female) where from?
    Do you have 'pick a part' help yourself or something similar nearby where you hock the parts yourself?
    Sep 2009
    I have one in a box in my shed... i think i may have chucked it out though.. it dont have much wire left coming out of it if i remember right, you may need to de-pin them with a small (like jewelers small) screwdriver and do your thing with it.
    Should be able to order through toyota, but i doubt it will be an instant over the counter buy to say the least.
    I highly doubt your gonna find one even at a self serve pick apart as they suit ONLY the 4agze ecu and no other 4ag series ecu.
    Apr 2009
    ahh cool, i did find out there is a pick and payless here. I suspected it was only a 4agze part. I only need the plug so the amount of wire coming out doesnt really matter. If you can find it that would be awesome, cheers!
    Sep 2009
    ill have a look for you tomorrow when im down in the shed tomorrow.
    Apr 2008
    As in your other thread, I got a AFM 4agze (24 pin) connector from a camry or toyota something of a similar age. If Casey can't help, try Kaizen Garage, Anthony will know which vehicles have the same, or can supply them.
    Look at any 3S, 1G, 4A computers. I don't know the exact engines that use the same connector (GZE, GTE, GE etc), but it's fairly common.
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
    I expect it is a fairly common denso ecu connector. I have a UZS131 ecu here with same plug same plug as MX83 . Also have a Mazda V6 and 4cyl Denso ecus from Mazda 626s with same plug in fact ALL 3 plugs from the UZS131 fit the Mazda ecus
    Jealousy is a curse
    Apr 2009
    had a short break to goto a large wrecking spares place in lansdowne today - no joy. thats 3 strikes
    will try pick and payless tomorrow
    cant believe its so hard to find a crappy connector
    look in some SV21 camry's, they will have the plug.
  1. What After market ecu 4AGZE
    By punkture in forum Tech and Conversions
    Last Post: 28-08-2009, 10:08 AM
  2. Info on 4AGZE ECU?
    By TERRA Operative in forum Tech and Conversions
    Last Post: 23-10-2008, 07:42 AM
  3. **bad info** 4agze Ecu
    By progkamol in forum Tech and Conversions
    Last Post: 26-07-2006, 04:38 PM
