My dad ran thicker oil in his landcruiser when it got around 300,000km's, That dulled the ticking but it was still faintly there. I was running 20W50 in my 18RC, Couldn't here any ticking at all![]()
Tappa tappa tappa. Sending me insane. Is there a way to quieten down lumpy cams on buckets? Would a different grade of oil help. I'm pretty sure the clearances are reasonably close. Would a thicker oil dull the hammering of the buckets or would a thinner oil free them up and keep the clearances tight?
Glen
NooB 3TGTE swapped RA40
✨Rahgo2:Turbo Boogaloo✨
Think I may have tracked down the thinner piston ringsJust got to do a few measurements to confirm this
Old School Fan
Thanks for the quick replies Justin and everyone else!
That's some serious power... Is the engine still going?
These are the specs on my reground cams... Will these do the job?
Also see attached full head rebuild receipt (only 25000kms ago, wanted to just chuck this head on as is if I could...) which includes heavier than stock valve springs and oversized exhaust valves... Would have been handy if they included the actual specs on how much heavier and how much oversized on the recipt as I can remember
[/QUOTE] TE=JustenGT8;1512154]With that spec engine you will piss it in. My old n/a made 112rwkw@5000rpm on a milder bottom end, with just decent cams and head port.
92mm bore is fine n/a and will actually make the engine revs a smidge more freely.
pretty much any gasket will be fine for n/a but a MLS can't hurt given your high comp ratio and the rish of a little bit of det.
Endorse light flywheel and as far as i have seen they are all good. Back in the day i had to have my own custom made and it was around 6kg for a very noticeable improvement.
You need cams, get cams !!272 total duration and 11ish mm lift will do the job nicely. Mine also had TRD oversized valves, which i would suggest. Keep the porting to jst a tidy up and it will still be very streetable but with an orgasmic induction roar?[/QUOTE]
Engine was sold long ago mate...early 90's. the buyer was playing with cam timing, god knows why, and forgot to put the lock pins in.....spun cams and bent every TRD valve
Your cams are pretty damn big duration wise and 10mm lift will be fine.
No detail on head mod work if any?, but the rebuild can't have hurt.
Build and enjoy![]()
My question for the day. If I was to play with my 18geu,s Afm and exhaust cam adjustment, which scenario would be better?
I'm thinking of advancing the exhaust cam to give me low end torque, but also changing the Afm adjustment wheel by 1 to 2 teeth, to give me a little richer fuel and there fore a better response. Is this scenario ok, or should it be one or the other?
Or should i retard the exhaust cam to give me a better top end, then adjust my AFM to give me the better low down responce?
i'm not sure if any other factors come into it. eg injectors CC's, or fuel pressure and stuff.
maybe not so much..
my previous RA28, R.I.P is here.
http://forums.toymods.org.au/index.p...t=0#msg_651396
Current build here.http://www.toymods.net/forums/showthread.php?t=33512
O__o
whats your offer ?
http://www.gumtree.com.au/s-ad/moont...spd/1013844616
He probably wants around 3-4k.
He also knows how to use a rattle can.
Seems they teach you that before spelling in SA![]()
if a car has no AFM then chances are its running MAP sensor instead
