Page 198 of 392 FirstFirst ... 98148188196197198199200208248298 ... LastLast
Results 2,956 to 2,970 of 5875
  1. #2956
    there's a sweet turbo manifold in the classifieds atm. you should check it out if your planning on going turbo.
  2. #2957
    May 2007
    cheers mite be worth keeping aside just incase !
  3. #2958
    May 2007
    Quote Originally Posted by 7M-GTE MX73 View Post
    just checked it out, that is too high for what I need. I prefer low mount turbo setup.
    I will either make one my self or find the old HKS seup from japan I see them come up every now and then..
  4. #2959
    Sydney N.S.W
    I know this may be an out there question, But.
    What engine, would be the closest engine, to the 18rgeu in terms of 2LTR, flap type AFM etc. also non turbo.
    a 4age is only 1.6ltr no AFM well some do
    a 3sge does not use an AFM
    was there a 4fe type of toyota engine?
    Then again it doesn't really have to be toyota engine. i don't think
  5. #2960
    Muziiz, currently I have built an 18R-GTE myself with a CT26 turbo on a low mount manifold and can give the following advice:
    Low mount can become very restrictive space wise. For the purposes of being able to get to anything, high mount becomes a viable alternative (although I must agree that low mount looks better)
    Go the EFI. The gear comes up regularly, and pretty much any aftermarket ECU will sort this motor out. Under $1000 will get you a new ECU, however I got all the gear for about $500 including a wideband oxy sensor by using the MegaSquirt 2 ECU.
    Stock pistons won't cut it above 10psi (less if you don't have a good tune). Detonation will kill them before you blink. About $750 will get you a set of forgies custom made from the states. You choose the bore size. A few of us have gone for 92mm for the extra capacity, others go with a closer to standard size for ease of finding head gaskets. Other parts are definitely available if you look.
    Good luck, I think the 18R-GTE is a rewarding engine. There is a thread on them on here.
  6. #2961
    If done well the low mount is not too restrictive. Mind you, when getting mine done the engine bay/engine location was measured and the air-con pump was placed on the engine so we could get it all fitted nicely. You should ceramic coat the manifold to reduce the heat and best to have some heat-shield to protect the alternator and also the air-con pump (assuming you have air-con). Any pipes/tubes that run along the passenger side of the engine bay should be relocated lower and/or given heat shield treatment. It does get pretty warm around that area.
    And yes, as Oman mentioned, a turb'd 18R-G is a massively fun engine which can put out some impressive numbers, depending on the build quality and how well the turbo/ECU/injectors are set-up, and of course the size of the turbo.
    seeyuzz
    river
  7. #2962
    Note: the physical size of the GT25 is a lot smaller than the CT26. Something to keep in mind when working out what turbo you want to run.
  8. #2963
    22re would be your best bet. Plentiful in the states. Alternatively you could look for the 18rg one..... i know of one that still has the efi manifold attached.......
    http://cgi.ebay.com/ebaymotors/1984-...Q5fAccessories
    bEn
    Quote Originally Posted by Omegaman View Post
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
  9. #2964
    Sydney N.S.W
    22RE are off a 83-84 celica ra65. 4runner and some trucks in the US.
    There about a 2.4 ltr SOHC though aren't they?
    yeh, still trying to narrow the search.
  10. #2965
    yeah something like that. From a visual perspective they are near identical. I can provide pics of an 18rgue one if needed.
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
  11. #2966
    Sydney N.S.W
    thanks, pics not req'd, as i have them.
    omegaman,
    Considered a sv11 camry? 2 litres FWD around 83-86? has an air flow meter same pinout I belive. I used one on my 3tgte with no problems, as the output voltage was fairly close.
    Roger
  13. #2968
    Sydney N.S.W
    Roger.
    i know the car, i'll check the spec's to see if it gives me the info i'm after.
    2S EFI computer and AFM has been done before.
    I met a guy who'd used a 4AGE one too. He said it worked, but needed a retune.
    (\__/)
    (")_(")
  15. #2970
    Sydney N.S.W
    guys,
    the comparison i'm after, is not to interchange. I'm just trying to confirm and have options for my emanage piggy back blue pinouts are correct and what alternative i can use to get the best out of it. Greddy do not have details for a geu install, so a similar engine may suffice. I have it running with no maps pretty well. But now it's all ready to be started and tuned.
