Page 162 of 392 FirstFirst ... 62112152160161162163164172212262 ... LastLast
Results 2,416 to 2,430 of 5875
  1. #2416
    Those top gun leads look just like the eagle leads.
    The not fitting issue can easily be solved by sliding the dust covers down the lead until they contact the tappet cover.
    My brother has been using that design and they've been fine other than the metal clip coming off every now an then.
    Some well placed lead clips also make them look quite organised.
    (\__/)
    (")_(")
  2. #2417
    I would love to eat a... Domestic Engineer Sagluren's Avatar
    south australia
    i have some ngk leads, fitted beautifully.
  3. #2418
    I recently got some NGK ones too, they look alright.
    (\__/)
    (")_(")
  4. #2419
    Junior Member 1st year Apprentice Little_Rolla's Avatar
    Tasmania
    got my 18RGU delivered today...
    Seems pretty clean,Also has the yamaha head on it 1111-88250 (i think).
    has a clunk when i turn it over, so i took the tappet cover off and the timing chain gets tight, then clunks and slops out... then it tightens again.. would this be a tensioner problem? there is some marks to show the chain has hit the tappet cover.
    Going to pull head and timing cover off to get a closer look and make sure no valves have kissed the pistons. and to replace the HG to be safe.
    and do i pull the head off first then the timing cover? and what pattern do i loosen the headbolts at?
    Regards
    Dan
    KE55 yellow, Low, Rebuilt 4k, sits in yard and not moves
    Green Mk1 Golf, Daily
    18RG RA40 in build
  5. #2420
  6. #2421
    Tasmania
    ahh cheers mate
    18RG RA40 in build
  7. #2422
    Quote Originally Posted by Little_Rolla View Post
    ahh cheers mate
    Some of those timing cover bolts can really hide from you too, especially if your motor is a dirty pig like mine.
  8. #2423
    Tasmania
    its rather clean, must have been rebuild or atleast freshend up withing last 12 months, engine block is a nice blue, new HD clutch,
    previous owner said it backfired out carbs and they caught fire. i seen the car and yeah all the fuel hoses, clutch cylinder ect where melted.. im guessing the warn timing chain jumped a tooth or two which cause timing to go out and bang... im hoping the valves havnt hit the pistons
    Ahhwell, all fun and games
    18RG RA40 in build
  9. #2424
    The NGK leads fit well for me. Anyone useing anything other than TRD or NGK needs to have another look IMHO.
  10. #2425
    not uncommon for them to fire back through carbs, thats often to do with cams espesh if they are big aftermarket ones. All 18rgs i've ever owned have fired back through the carbs occasionly. meh. If the chain has jumped a gear then the engine will be fubar-ed. I genuinely believe that the chain cannot jump over, well i did till it happened to my mates 18rg. High revs doing a burnout and oil pressure dropped, lost tension in chain and wham bam thank you maam. 7 valves bent like bananas and the 8th on not too straight either. Somehow he managed to limp it home.
    Alternatively too the carbies could have been really farked too, It shouldn't spit out that much fuel. If it spits any fuel out under normal operation it'll get sucked back in next revolution of the engine.
    Compression test ftw before removing the head. If no compression then pull apart, if it has good compression then get some carbies and give it a go!
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
  11. #2426
    Junior Member Grease Monkey MnToyGuy's Avatar
    Minnesota
    Hey all,
    Just picked up a 18RG recently and got a few Q's
    motor has been sitting in shed for about 9 months (thats when it was last run)
    Is there anything i HAVE to replace before using it? i know ive had a few 4k engines have the water pump bearings die if sat for a while.
    2nd, it came with no carbs but has the manifold. will 40MM DCOE webers fit? quick google has led me to belive they are same as the solex and minkuni (spelling) carbs bolt pattern wise.
    3rd, if carbs do fit, whats a base jet size to start at? the carbs where off my 1.8L golf Engine.
    now all i gotta do is find a car to put it in haha,
    Regards
    Dan
    Everything you wanted to know about jetting for the RG:
    http://www.rmcarburetors.net/Tuning%20Tips.htm
  12. #2427
    Tasmania
    Cheers mate,
    Have decided to go EFI on this setup. and its going in a RA40 celica
    Have got the head off and its on its way to get a skim, manifold sides skimmed, cleaned, crack test ect ect.
    Timing cover will be coming off once i got my engine stand. then the Timing gear will be replaced. anything else worth doing while its stripped half down? it has a new clutch, flywheel is good,
    18RG RA40 in build
  13. #2428
    south australia
    sump gasket, i always had trouble when i was replacing them in the car.
  14. #2429
    practicing idiot Automotive Encyclopaedia sheepers's Avatar
    May 2006
    New Zealand
    can anyone tell me what this head is off???
  15. #2430
    222 head is a 2T-G head, unless I am very much mistaken.
    seeyuzz
    river
