Page 321 of 392 FirstFirst ... 221271311319320321322323331371 ... LastLast
Results 4,801 to 4,815 of 5875
  1. #4801
    Ideally i would use an aftermarket ecu with a proper tps and map sensor to get rid of the flappybox, but due to state law i cannot sacrifice the factory ecu and emissions equipment and still get it signed off by regency park unless i do independent emissions testing which can cost thousands of dollars.
    This has also got me thinking - because the 18RGEU ECU only gets its rpm signal from the coil, it won't have a 'home' position. This means that it's either wired up for 1+2 and 3+4 because it doesn't know which cycle it's on, thus one of the pair will be kn the right cycle (but, again, no home position, so how can it know which pair to fire?) or it just fires all 4 of the injectors at the same time...
  2. #4802
    Infact firing all a once is the most likely method of operation and they're only split in to pairs to reduce load on the ancient injector drivers.
  3. #4803
    It only takes minutes to wire in an aftermarket ecu like a haltech and I'm positive that you can hide it well enough to not have them know its not stock, or you could just put the aftermarket ecu in the stock ecu case.
  4. #4804
    No idea how it fires the injectors. I'll whack the silly scope on it the next time I get a chance.
  5. #4805
    Spank your Grease Monkey Otaku's Avatar
    Found some injectors out of my 4age i'm rebuilding with the part number 23250-34030, searching up this part number tells me that they are 18R-GEU injectors. Weird thing is I can also find these injectors on ebay (USA) where sellers say they came out of a AE86/MR2 4age but I can't match this part number with any 4age's. Here is a pic of one of the injectors:
    Just wanna know what injectors I have because I need a replacement.
    otaku.harley
    hachiroku.com.au
  6. #4806
    ToyoDIY.com
    seem to only list them for 18rgeu's?
    (FWIW they look like the ones in my 18rgeu)
  7. #4807
    Sydney N.S.W
    Quote Originally Posted by Otaku View Post
    there not the 18rgeu std one's, as they are 210cc, these are 252cc /24lb/hr 3(bar) 2.8ohm, so they may be MR2 type. as long as they are single pintle, they would suit an RG quite well. they are the same colour as the 18rgeu std though.
    edit, talk about confusion. Another sight says they are 216cc 2.2ohms 3bar.
  8. #4808
    Crikey... I run 700cc injectors on mine.
    seeyuzz
    river
  9. #4809
    Mate, sounds like your best bet is to take a working injector to a fuel injection place and get it tested...
    OMR: and the way you drive I bet it doesn't even get close to 50% duty cycle!
  10. #4810
    Sydney N.S.W
    seeyuzz
    river
    Oh, the benifits of a stand alone ECU over std ECU. ;(
  11. #4811
    Mine probably doesn't even do 25% duty cycle!
    Look at it this way, when OMR is going to sell off some classic Celicas you can be well ensured they are not only in top condition, but mechanically they have been looked after and will run for another 40 years.
    seeyuzz
    river
  12. #4812
    Top End
    seeyuzz
    river
    hmmmmmm i have my reservations on things with electrickery (inj, ecu, ign, fuel pumps) lasting 20 years let alone 40
    Once apon-a-time world famous Photochopper
    http://zammothechoppa.deviantart.com/ : )
  13. #4813
    Bahhh, easy peasy. Fix them or buy whatever the latest gizmo is at the time. Mind you though, in 40 years the only gizmo's you'll probably be able to buy would be to get an extra few watts from your awesome elecvtric car motor.
    seeyuzz
    river
  14. #4814
    Sydney N.S.W
    any ideas?
    My 18rgeu is not sending the signal to turn on the fuel pump at the relays.
    the relays are working, as i tested them with meter. The AFM has power at all the right points.
    i've looked at the TPS and adjusted to 0 and 5v at wot.
    my fuel pumps/lift pump work with direct power. car starts and runs that way.
    what else could be the problem. i only once i got a alternating signal from the fuel pump wire when testing, but i can't replicate it.
    any suggestions?
  15. #4815
    Top End
    Quote Originally Posted by Omegaman View Post
    do that
    run a toggle switch under the dash doubles as an anti theft device
