Page 291 of 392 FirstFirst ... 191241281289290291292293301341391 ... LastLast
Results 4,351 to 4,365 of 5875
  1. #4351
    going back a couple of pages..... back to the flywheel discussion.
    I ended up with a 7kg billet flywheel. $440
  2. #4352
    Aug 2009
    Are ya going to use a Victa pull cord on this?
    Rgds, Willofan
  3. #4353
    Top End
    and that came from where and _____________ if you dont mind me asking
    Once apon-a-time world famous Photochopper
    http://zammothechoppa.deviantart.com/ : )
  4. #4354
    Is billet, is good
    Quote Originally Posted by The Witzl View Post
    Now what sort of a clutch are you going to run?
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
  6. #4356
    Toyota for life REP! Backyard Mechanic TTV8RA23's Avatar
    Jun 2006
    Whakatane
    That is very nice! Great for the price too!
    Simon
    Kiwi back yard mechanic/fabricator/machinist/welder
    http://www.toymods.net/forums/showth...t=tt1uzfe+RA23]
  7. #4357
    running a exedy cushioned Sports Tuff heavy duty 8-puk disc and high clamp force pressure plate (yet to order - will get from NPC in brisbane most likely).
    The flywheel came from Direct Clutch Services up in brissy as well.
    hopefully it will hold up to teh powahs.
  8. #4358
    Aug 2010
    S.E.Q.
    Hey!, Witzl. How can you scratch your butt if you have no ring gear ?
    What does a ring gear weigh ?
    Owen.
  9. #4359
    i'll be cracking the ring gear off a 2nd hand flywheel, or buying a new one and fitting it.
    Apparently its a piece of piss to fit the ring gear.
    ... so relax everyone
  10. #4360
    Jan 2012
    Finland
    Old gear is easy to remove;just lay the flywheel on the table and start tapping the gear with small hammer.Go around the gear as it moves so it stay straight.When removed heat it some way (100ºC is enough) and it will drop on new flywheel.Have hammer ready if it happen to stuck on the way..
  11. #4361
    Toymods Club Member 1st year Apprentice
    Apr 2010
    Hey guys, I'm having an issue with oil spraying out the breathers. Any ideas? My post is here: http://www.toymods.org.au/forums/tec...r-g-gurus.html
    Thanks.
  12. #4362
    Top End
    Cool Re: For the love of a tractor engine: The life and times of the 18R-G
    MOST AWESOME RG RELATED NEWS FOR ME
    My search for an RG is over and seems it will only cost me a flight home and transport to Darwin
    The reason being is MOST OF MY OLD RG STUFF IS STILL IN A SHED DOWN HOME at the least I have 1 RG block with a set of LOW km chains and guides, TRD oil pump, reco head with OS SS valves Rebuilt SOLEXs Plus all the little bits for the pump drive, manis and what not. Now there may still be 288 or 292 brand new cams cant remember which and 13 hole adj gears, spare full set of rods, pistons and rings, crank, chains , guides, tensioners, timing cover, complete new gasket set, assorted inlet manifolds and custom extractors for the RT40 if im lucky and the exhaust was taken out of the shell before it was sold. Even if i have half of any of that i will be as happy as pedo bear at miss kindy pageant the mate thats storing it says i have most of it from what he can tell and as a different mate saved the stuff and a differnet one help himself to some bits only the Gbox im led to believe (close ratio rally spec w50 dog box ) i cant be sure whats there till i go down and look myself. If im really lucky theres 4.11 hilux LSD diff center and custom tailshaft somewhere too.
    After being stored for nearly a decade ive no idea on the condition of any of this, most good things were wrapped in oily rags and and put in plastic bags but cant be sure it all still is and how long it may not have been. My biggest fear is the head may have been moved several times with some valves open resulting in bends. Any rubber seals and O-rings maybe perished but thats no that big a deal. Main concern will be corrosion how much and how deep ???? my hand sanded & polished bits will all prob need to be redone.
    heres a pic of said motor incase anyone wants a looky
    And heres a pick of the RT40 i will be putting it in once i get everything up to darwin
    The hard bit now will be disc brake front end where am i gunna find one of those.
  13. #4363
    I don't want to be a Domestic Engineer bnicho's Avatar
    Quote Originally Posted by Zammo View Post
    Find an RT81 with disks.
    Rob the parts and bolt them on.
  14. #4364
    Top End
    I know what to look for its where, there wont be any up here in NT i think but i will look i wont have much time in brizzy to look when i go down there and they arent that common
    wondering if i can go full custom ?????? and how much itll cost
  15. #4365
    Nov 2007
    Okay guys i have some cam questions. I have a pair of cams i've traced back as a set ground for sean malony. There is a 286 and a 312 advertised duration. The person i got them off said the 286 was intake and 312 was exhaust however the cams have marks, which i assume are timing marks, but they don't match the timing card. Looking at the position of the marks they look like they would line up at 12o'clock for opening points if the cams were swapped (312 intake 286 exhaust) is it more likely the higher duration cam should be on the intake? And does anyone have an engine that was built by sean that they could check for cam markings?
    Glen
    RA28 (18RG)Members Ride
    RA40 (3TGTE)
    RA40 (18RC)
    SXA11R Rav4 Cruiser
    ACA33R Rav4 Cruiser
