Page 222 of 392 FirstFirst ... 122172212220221222223224232272322 ... LastLast
Results 3,316 to 3,330 of 5875
  1. #3316
    They can be redrilled quite easily, and it does make it easier to time in aftermarket cams. We got my brother cam's spot on by drilling two extra holes to the left and two extra holes to the right using the same spacing as the other holes (roughly). Tosco used this set up and it worked for them.
    (We were setting up 13 hole HKS cams, which made it a little easier too).
    (\__/)
    (")_(")
  2. #3317
    Paying somebody to properly measure and drill a hole for you would likely be dearer than the aftermarket adjustables.
    At some point I'll look at getting a set of the vernier adjustables, but that's going to be a little ways down the track, I'll see how the CT26 lasts first.
  3. #3318
    It wasn't expensive when I got it done. I reckon it's a very easy job if you've got a drill press and a clue.
    I set to work using the CNC mill during my last teaching placement.
    All I have left to do on my prototype vernier cam gears is to grind off the excess stock from the back of the ring gear. So far it has all worked out very well.
    They've cost me a grand total of about $20 in materials and only hours in labour.
    I think I'd like to get some better quality sprocket blanks as the ones I bought were a bit shit ($5 each for a brand new through bored blank).
    (\__/)
    (")_(")
  4. #3319
    nice datsun Backyard Mechanic TRD184's Avatar
    Jan 2009
    New South Wales
    never mind
    my RA23 http://www.toymods.org.au/forums/showthread.php?t=57060&page=2"]
    It's 106 miles to Chicago, we got a full tanks of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
    - Hit it.
  5. #3320
    TRD184.
    Never mind, but PHH44 Mikunis have been delivered on JDM Datsun Roadsters and some Datsun 510s.
    The Roadster also came with the PHH44-2 (Type Q).
    Mikuni make no more Sidedraught PHH styles since mid 90's but they can be found in all sorts of condition around the world.
    Regards
    Rodger
  6. #3321
    Junior Member Backyard Mechanic egamirrorim's Avatar
    Are the 18RC thermostats the same as the 18RG ones? Having trouble finding an RG one brand new...
  7. #3322
    egamirrorim,
    The thermostat itself is interchangeable between the 18R-C and 18R-G. If you look properly, you will find a range of different temperature operations at your disposal, depending on how hot it gets where you live, and what temperatures your engine likes to run at will determine what thermostat you should get. The standard 18R-C item seemed to work fine for me in standard 18R-G's in Townsville's heat though.
  8. #3323
    Jan 2009
    New South Wales
    thanks, sorted
    - Hit it.
  9. #3324
    Clutch and gearbox input shaft spring to mind as possibilities.
  10. #3325
    Jan 2009
    New South Wales
    hmmm, sounds higher up then that. is there a known way i can confirm that if it was that?
    got me thinking about thrust bearings now, or would that do it in neutral aswell? unless the pressure from the clutch moves the crank forward that little bit?
    - Hit it.
  11. #3326
    Jan 2009
    New South Wales
    hey guys
    did a compression test on my 18R-GU today, ended up with 120 psi across all four of them, its great thats theyre all even but is that kind of figure normal for the emission controlled engine?
    - Hit it.
  12. #3327
    The figure can be greatly influenced by cam timing and valve clearance. I have seen 120 across all 4 on a healthy engine before. The aggressive cams of the 18R-G family of engines tend to give them low compression readings even though the static compression ratios are relatively high.
  13. #3328
    Jan 2009
    New South Wales
    aaah ok, i did a search and found some people mentioning figures as high as 175, and others as low as 110, so was worrying a bit. thank you
    You must spread some Reputation around before giving it to o_man_ra23 again.
    - Hit it.
  14. #3329
    Quote Originally Posted by o_man_ra23 View Post
    egamirrorim,
    I live in Sydney so I dont think extreme heat will be a factor...
    Thanks heaps for the info! + rep
  15. #3330
    Flywheel question. Last piece to the Oman's 18R-GTE revision 2 puzzle is the flywheel. Stock item is not suited to that much power, and an aftermarket item is proving hard to find. Both Kameari and Jun Chromoly items are on 3 to 4 month back order, so the delay is pretty well unacceptable. The only other option I have come across is the Fidanza aluminium item (approx the same weight as the Kameari CrMo).
    Are there any other light weight high strength flywheels suited to either 18R or 22R which anyone knows of that aren't exhorbitantly expensive?? I say 22R also because they run the 11 x 1.25 pitch thread that I have reamed my crank out to, as opposed to the 18R 10 x 1.25.
