W50 identity 101. The clutch fork will be one of two types. The early model is a cast iron item, and the clutch slave push pin will protrude through a hole in it. It also has a small hole on the end for a tension spring back to the slave cylinder. The other type has a pressed steel throwout fork. If you have an early type, then 1976 RA23 will definitely get you the right clutch kit. If you have the later type, then 1981 RA40 will get the right clutch kit. The throwout bearing is the only difference in the kits. The later kit will also fit the W55, 57 and 58. As mentioned, the 18R-C kit is the same in every respect to the 18R-G kit, aside from the stupid looks you get from unseasoned parts interpreters.
As for the 'baffling' mentioned earlier, what you see is actually a windage tray to scrape the excess oil off the crank (doesn't touch). This is present on both the 18R-C and 18R-G variants, and everything in between. The sumps are all fundamentally the same, aside from any oil level sensor fittings etc on specific models. Adding extra baffling if you want anything to go on a race track with turns is a good idea, as long right handers tend to turn 18R's to scrap metal all too often.
