For the oil pump, check the 18R-GTE thread, as MnToyGuy is getting some uber pumps made for 18R-G.
If you are doing an 18R-G, definitely use the 9.7:1 compression pistons, as these will provide greater torque, and from experience, they certainly make a light car take off nicely, so no, you won't have torque issues. You only tend to get torque issues when putting a 4A-G into a car weighing more than 800kgs.
I have a 18rgeu. here is a couple pics for reference. the pistons, are decidedly not geu items. what engine configuration would use high compression pistons, and 270 series head and cam? It came with a super deep. milodin oil pan, that seems massive to me. should I consider the depth of oil pan vs. stock oil pump? head looks to be ported. I'm gonna carb it, and keep it simple. can any of you i.d this piston? the reason I ask, I have concerns about u.s. fuel and detonation. a local here is busting my balls about reusing these pistons. I've posted about this before. could I build the motor, and deal with static comp. via the head gasket sizes? in other words, if it detonates, pull the head and try a thicker gasket. is this half assed.? my priority is reliability.
Last edited by mark corona II; 04-01-2010 at 04:04 AM. Reason: hard returns between images for better viewing
Could you please edit your post and press "enter" between the photos? It would make it easier for me to fit on my screen.
Can you show us some different angles of the pistons and also the underside (inside).
We might be able to give you an indication of what your compression ratio would be with those pistons.
Have you measured them for bore size? Measuring the block might be better.
(that will kame a difference to our compression estimations.
Can you put up any pictures of the cam lobes?
They may have been reground to suit the pistons but retain the original casting numbers.
Have you got pictures of the oil pick up? Does it reach the bottom of that sump?
It looks like you've got a good set of pistons there, I think it would be good to reuse them if they are not damaged. Engines can be set up to suit high compression pistons.
My brother's RG is running 11:1 compression on 98RON fuel (upper-premuim pump fuel) and is doing well. Still haven't finished running it in yet or had it properly tuned, but it look sto be fine.
(\__/)
(")_(")
Looking at the casting, those pistons are aftermarket, and way more than 9.7:1 compression. I would say the engine was originally an 18R-GUE, but has been uber worked. Agreed also that the cams would have been re-ground. That isn't a normal set of pistons, and if they aren't fooked, they should be re-used. If the bores are worn, an those pistons are bigger than standard, then get an 18R-C block (they should be common as dogs balls for you too) and get it built to suit. The actual block castings are the same between 18R-C and the -G series.
It would be interesting to see a pic of the oil pump used in this motor.
With the depth of the oil pan, some mods must have been done in that area.
If so, what mods were done?![]()
my previous RA28, R.I.P is here.
http://forums.toymods.org.au/index.p...t=0#msg_651396
Current build here.http://www.toymods.net/forums/showthread.php?t=33512
here are the requested pics. no oil pump came with the motor. I think this will be the hardest to find/get right. are the pics better?
hI,
Not hard to swap the dipstick to the other side anyway. I think it is on the passengers side on the rg because the carbies make it difficult to get at. From memory though everything else is the same.
Keep in mind too though on the 88270 engine the pump drive shaft doesn't have the lobe needed for the fuel pump so you have to go for an electric one ;-)
bEn
FJ40 landcruiser
HJ47 landcruiser
FJ55 Landcruiser
MS65 Crown
That is one serious hump in the sump and would have been one long pump to reach the bottom of the sump hump. It could have only been used in a 4x4 truck with that depth.
May I recommend you acquire a another sump and RG pump that better suits your crossmember/steering in the old RT MKII.
I am sure someone here in OZ can help you out if you need these bitz.
Rgds, Willofan
Those cams have definitely been reground to something much more agressive than the standard 18RGEU cam.
For this reason, I think you will be ok with your big pistons as long as you have the ignition timing tuned properly and run it on high grade pump fuel. (I don't know anything about US pump fuels).
You should have the camshaft profile measured in relation to the standard timing mark so that you'll be able to set them up properly after the rebuild. If you have the specifications for them, then this will not be required.
(\__/)
(")_(")
Note the HKS cast into the underside of the pistons. These are definitely aftermarket. The cams are a regrind and look like a low lift, high duration item. Do they have any grindings in the front face of them (a number put there later??) This could give an indication of spec.
River, to move the oil dipstick, you remove the blanking plug from the non-dipstick side to reveal the already cast and machined hole ready to put your dipstick tube. That blanking plug then replaces the dipstick tube on the other side. Casting is therefore the same. There was also the stamping of the engine number which is upside down on -G blocks, but this is not a casting. I am yet to see a difference in casting between the blocks, even the oil and water galleries are in the same spots, and seemingly the same size.
