Page 100 of 392 FirstFirst ... 50909899100101102110150200 ... LastLast
Results 1,486 to 1,500 of 5875
  1. #1486
    cheers rad im currently wining one on ebay
    also i measured my 88230 valves with vernias
    inlet- 45.03
    exhaust- 38.51
  2. #1487
    Hey guys,
    Finally got time to take the cams off and measure the shims.
    I am aiming to get the clearances closer to .32-.34 so am on the look out this weekend if someone in my area (ipswich, qld) had some shims in the size I need. (otherwise I'll just order some on monday)
    This is what I have and what I want to aim for:
    (ARGH it formats ok, but when saving changes it removes all the spaces!!)
    exhaust Clearance Existing Shim Shim Size
    Shim Difference Wanted
    1 0.25 2.54 0.09 2.45
    2 0.25 2.5 0.09 2.41
    3 0.23 2.59 0.11 2.48
    4 0.23 2.47 0.11 2.36
    Inlet Clearance Existing Shim Shim Size
    1 0.2 2.19 0.09 2.1
    2 0.19 2.24 0.1 2.14
    3 0.2 2.24 0.09 2.15
    4 0.23 2.29 0.06 2.23
    I can mix and match 3 of my existing shims to give me the desired clearances which is a bummer. I measured up the spare head I've got and can only use one shim from that lot too
    Anyway, if someone around my area has some I can buy, give me a PM please
    Dave
  3. #1488
    floppy,
    Did you see the contact details I posted for a shim manufacturer not too long ago?
    (\__/)
    (")_(")
  4. #1489
    Hi Steve,
    If its the Precision Shims guy, then yeah
    I am going to ring him tomorrow and order from him.
    From his www parts page, I am guessing I need the bucket and shim type of diameter 13.8mm in the thicknesses I tried to show in the previous post.
    I'm a bit concerned his minimum thickness is below what I need for the intake side, I'd hazard a guess that the valve stems hadn't been ground on this head ;(
    Was there another company that does shims?
    Thanks
    Dave
  5. #1490
    Melbourne Victoria
    FLOPPY inlet is between 9 to 13 thou and exhaust is between 11 to 15 thou and monday is a public holiday here as well
    what sizes are you after in mm please ,i might them in stock i have shims from 1.70 up to 4.0mm
  6. #1491
    did fuel injected blocks (88270) have a drive for the fuel pump on the aux shaft? it appears mine doesn't looks like i'll go with an electric pump
  7. #1492
    Mechanical fuel pumps are poo, I'd be getting an electric one regardless.
  8. #1493
    I would hazzard a guess... considering I have an 18R-GEU which was converted to carbs, and say yes... as there was a mechanical pump hanging off the side of mine, and I really doubt they would have changed out the aux. shaft when they imported them and changed them to carbies (common practice back in the day)
    Pull the cover off, rotate the crank and see if there is a lobe going round... easiest way to find out.
  9. #1494
    There is no lobe on both of the shafts just a gear to drive the oil pump. but there was a fuel pump on there but all of the lines were blocked off. could i use an 18rc one if i put the 18rg cogs on? or is this not possiable?
  10. #1495
    Nope, sorry... the 18RG aux. shaft is longer at the front to allow for the dizzy drive gear.
  11. #1496
    hosking, that's correct, the 18RGEU aux shafts have no lobe for the fuel pump, or at least the later ones didn't. I've got a couple of those nicely balanced shafts myself and no, like Owen said, an 18R-C one won't do the job.
    (\__/)
    (")_(")
  12. #1497
    Swap you your nicely balanced shaft for my lobe'd shaft.
  13. #1498
    Owen, I'll let you can keep your lobed shaft.
    I plan to build a couple of 18RGs and both of them will be EFI. Plus I have lobed shafts too.
    (\__/)
    (")_(")
  14. #1499
    Steve, I was actually talking to Hosking... sorry for any confusion caused.
  15. #1500
    if you want it pm me i have two nicely balanced shafts
