batch and multipoint are similar but yours are wired up as batched, but not sure weather the wiring to multipoint is the same as ive never wired up using multipoint. they may well be identical and might not matter a shit....
heres a quick run down on the difference.
Batch mode injection fires the injectors in two even groups. This is aimed at reducing fuel rail pressure fluctuations. This mode of injection does not require any home or reference signal to operate. The angle of injection is not defined, and the injection angle map is not used. The frequency of injection is defined by the Ignition Divide By parameter. Batch mode is not available for engines with odd numbers of cylinders. Batch mode is not available for Motronic triggers.
o Multipoint mode injection is the most basic form of injection that fires all injectors simultaneously. This mode of injection does not require any home or reference signal to operate. The angle of injection is not defined, and the injection angle map is not used. The frequency of injection is defined by the Ignition Divide By parameter.
