Results 16 to 23 of 23
Thread: Need HELP 1g dizzy problems
    Toymods Tuner Backyard Mechanic Forcefed6's Avatar
    Default Re: Need HELP 1g dizzy problems
    I didn't weld the hole up... I found an NA housing and used that. If you are going to weld it, any competent welder should be able o do a good job.
    Linden (I think Roadrunner Performance?) should be able to do it easy enough. Rod might be able to help you out with his contact details.
    Mine should be going again one day... No auto yet, but it is on the way. Has been ordered, just basically waiting on the convertor to be built now. Car is getting a respray anyway, so no real hurry. If you want to know more, check it out in one of the links in my Signiture.
    Z10 Soarer - [email protected] ... 11's soon
    CHECK IT OUT HERE
    Roadrunner Fabrications are Toymods Newest forum sponsor and Linden can be contacted on 0410 507 715
    He is located at Unit a13/16a Amax Ave, Giraween. NSW
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    ive been told that q bond will seal it, that shit's pretty f*#@ing good!!!
    Quote Originally Posted by Jordan 76
    I knew that stuff was good, but I didn't think it was that good. Interested to see how it holds up if you do it.
    CHECK IT OUT HERE
    i'll be doin it tommorow, but wont be able to start the car til next week to see if it holds the pressure, i'll let you know
    Junior Member Domestic Engineer mic*'s Avatar
    Hey forcefed, where did you tap into to get your coolant lines for the turbo?
    meh...
    Hey forcefed, where did you run your coolant line to the turbo from?
    meh...
    I am not actually using the coolant lines. The turbos I am using don't require to be water cooled. If it is required, tapping into the heater lines is all that is needed.
    CHECK IT OUT HERE
  1. 4AGE 100kW Dizzy Oil Leak Guide
    By Talasas in forum Tech and Conversions
    Last Post: 05-11-2014, 09:00 PM
  2. How to avoid dizzy on 4age?
    By MarkIIRx12 in forum Tech and Conversions
    Last Post: 18-01-2007, 08:42 AM
  3. Problems solving 4agze
    Last Post: 28-06-2006, 07:21 PM
