Results 1 to 15 of 24
Thread: Rebuilding a 2TG
    Default Rebuilding a 2TG
    Does anyone have any rebuilding manual for the 2TG engine?
    I bought one for my car but unsure if it runs so before I transplant it in my car I was thinking of rebuilding it. Any help appreciated. Also can you buy any parts for this engine from any autoparts shop or do you have to go to Toyota.
    Alex
    Default Re: Rebuilding a 2TG
    Quote Originally Posted by myTA22
    Alex
    Hi mate
    I've got a manual here that you could use and also i work for toyota so let me know what you need and i'll try and find the parts for you. You should be able to find most parts from autoshops aswell.
    craig
    Alex
    http://www.swmotorsport.com/
    most components you will need is there, also what head do you have?
    when i bought a complete gasket kit from another auto shop it was for a 88260 head (oval timing chain inspection plate) when i needed a 88222 (rectangular timing chain inspection plate).
    It was an easy fix, i got some gasket paper, traced around the outside of the plate, cut it out, pressed hard on the inside edges so that they had an in-print on the gasket paper and cut the inside out.
    http://www.redlineauto.com.au/
    for soft mounts, the rubber gasket that goes between your solex carby and the intake manifold.
    http://www.carburettorservice.com.au/
    for carby tunning, and suppling ram tubes and ram socks for carbies
    http://www.rmcarburetors.net/
    Rodger's site, all you need for your solex and other carby needs.
    do a search and you will find rivers thread and Thetoymans thread all about the 2T-G
    CraigD, is that the green 2T-G manual? if so would you consider selling it.
    deepdishfactory
    before i for get:
    http://www.toymods.net/forums/showthread.php?t=16951
    electronic ignition for the 2T-G, something to invest in while you are in the rebuilding stage.
    fonzy
    deepdishfactory
    Quote Originally Posted by w810sc
    Yeh it is.
    Sorry dude i wanna hold on to this.
    Junior Member Domestic Engineer tricky's Avatar
    Keep your eyes on e-bay. Genuine 2t engine manuals pop up less frequently than 18r ones, but there is still probably one every two weeks or so. I bought one for my brother recently. In fact, there's one on there now... But don't all bid on it at once .
    If you want any specific data, send me a PM and I'll send it to you. Good luck!
    Nikita the RA23 is almost finished .
    http://search.ebay.com/search/search...&fsop=1&fsoo=1
    yeah only for the 2T. One day ill find one for the 2T-G.
    deepdishfactory
    Quote Originally Posted by CraigD
    Hi mate
    craig
    Thanks, were abouts are you located, im in quakers hill
    I just looked at the engine and the head is a 11111-88220
    Is that a latter model head or early?
    Sorry for the stupid question but been a mazda man most of my life, I bought this car 3 months ago and dont know much about them, slowly trying to learn.
    88220 is the early heads, smaller valves intake and exhaust, different style valve cover and rectangular type timing chain inspection plate.
    River's thread:
    http://www.toymods.net/forums/showth...&highlight=2tg
    Thetoymans thread:
    search:
    http://www.toymods.net/forums/search...earchid=289495
    keep us posted on your re-build
    fonzy
    deepdishfactory
    I'm in parra but work in castle hill
    I have the 2T-G rebuild manual and I've scanned it to CD.
    seeyuzz
    river
    Woops, my bad. I assumed the 2t one had the 2tg as well. Turns out the one I bought for my brother was the T-series engine manual. After some appropriate revision of the ebay search, there is one... But it's in the US, so I guess it depends on how desperate you are.
    Quote Originally Posted by river
    seeyuzz
    river
    Any change of gettin a backup of this cd ?
    Alex,
    If you are rebuilding your 2TG and happen to have a 3T in it now then if the budget allows it would be the perfect time to rebuild your 2TG as a Hybrid. Theres allot of info on the site about what you need to do but for the budget conscious you could just have your 3T pistons flycut to clear the 2TG valves
    Good luck with it and I wouldn't be concerned about having the small valve head unless you were planning on chasing some big numbers.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
  1. 2TG Rocker Cover Guide - With Pics
    By TheToyman75 in forum Tech and Conversions
    Last Post: 28-05-2015, 09:56 AM
  2. TG engine info!
    By MitchE in forum Tech and Conversions
    Last Post: 30-07-2010, 06:27 PM
  3. Just how far can you go with a 2TG?
    By JUSTIN K in forum Tech and Conversions
    Last Post: 18-04-2007, 06:29 PM
  4. 2tg race parts and gear drives
    By Celica RA45 in forum Tech and Conversions
    Last Post: 25-01-2007, 08:47 PM
  5. 2tgue & 3tgtue info
    By chippa07 in forum Tech and Conversions
    Last Post: 06-01-2007, 07:29 PM
