No cameraOriginally Posted by joecoolmk2
I'll borrow one when im done and it all looks nice.
I mean the WHOLE drage link, the rack moves the drag link (from the center) from left to right. Note the only point of taking it that far is to have power steering and reduce the play from the old boxes.
Here is a suitable rack:
http://cgi.ebay.com.au/HOLDEN-CAMIRA...QQcmdZViewItem
You would take the camira drag link off (the black metal pole of the right) and attack the center of the rack to the center to the center of your drag link. As you can see the camira drag link (that isnt its real name, but for lack of a better word) is bent in at the center where it mounts (to two bolts), to achieve this on a normal drag link drill the two holes and put a spacer between the drag link and rack. - i welded one in a first test fit, but ditched it.
As i said, up to here is just getting rid of that steering slack/play, to really improve the steering you need to mod the drag link to a different size (matching to LCA mounts) and use different tie rods.
Also, for support, the after market ones have linear tracking across the drag link, to achieve this simply leave the idler arm and pitman arm ON, but some linear tracking with bearings would be better.
