Results 1 to 4 of 4
Thread: 1g-fe Wiring Harness Connectors?
    ASL? Backyard Mechanic thegreatestben's Avatar
    Feb 2007
    Default 1g-fe Wiring Harness Connectors?
    I'm in the process of swapping my 1g-fe to 1ggte.
    Question is Does anyone have a diagram of the connectors to the body loom?
    I'm not sure If this is the correct name but its the plugs that have all the dash signals etc...
    I've got the 1ggte ones but can't seem to find the 1G-FE ones anywhere.
    I'm a noob at this, First time engine swap so be nice!
    Default Re: 1g-fe Wiring Harness Connectors?
    you probably have to tell us what car as the body loom connectors would differ car to car.
    Black Betty >HERE!<
    (\__/)
    Feb 2007
    Ah that probably would help.
    Car is a GX81 Chaser - 1G-FE AUTO
    Engine Is GA70 1G-GTE MANUAL ECU GEN 3
    If anyone can tell me whether the MX83 ones are the same I've got that diagram.
    I've searched and searched and can't find what I'm after.
    Feb 2007
    Ok so who wants to help me. I'm modifying a GA70 Gen 3 1ggte to fit into my GX81 Chaser.
    I'm having trouble Identifying the body loom wires on the Motor. Perhaps I'm reading diagram wrong or something. I can't seem to match my body loom plugs to the ones in the supposed 1ggte Gen 3 Diagram that I found on this forum. I just need a push in the right direction To get this sorted as its taking alot longer than It really should to get the car done.
    So if someone could make things blatently obvious for me itd be great here are some photos.
    And teh other question i have is can anyone I.D. this wire?
    It comes down between gap in the inlet manifold. Its quite thick and is black with a blue stripe.
  1. 20v to 16v conversion and wiring harness
    By Mexican 5 in forum Tech and Conversions
    Last Post: 08-03-2007, 12:58 PM
