Results 1 to 10 of 10
Thread: Thermo Fan Wiring best practise + best for a novice
    Default Thermo Fan Wiring best practise + best for a novice
    gday, ive now today fitted a set of EL falcon dual thermo fans into my 7mgte powered soarer. Its all bolted in nice and secure ready to be wired.
    I have powered the units from the car's battery and they both spin easily and theres alot CFM in the units.
    I have done a search and found witzl's guide http://toymods.net/forums/showthread...oswitch+wiring but i have to say it is well beyond me I wouldnt know the first thing about taping into the stock thermo switch (located that from the guide above) or getting power only when ignition is on, i simply dont know how to do it.
    Short of paying for an autoelec to set it up for me (more than willing to pay to get the job done properly) does anyone know of any good BASIC guides to help me out?
    All help appreciated, and if someone in SA is willing to wire the thermos for me, im willing to pay a decent hrly ammount ;-)
    Default Re: Thermo Fan Wiring best practise + best for a novice
    that is a good guide in my eyes if those things mean nothing to you, i think you should just pay someone or ask a mate to do it for you
    yeah im leaning towards that, specially since the car is a 7m ;-)
    Montrose
    Install a suitable switch, use a relay and fuse and a few bits of wire. Dead easy. Just don't use one of those horrible 'adjustable' 1950's style switches!
    where should i install the thermo switch to? my radiator doesnt have a suitable point in which to install the switch to.
    also, for power on ignition, i assume the TSN/supra wiring diagram website will give me the info i need?
    Im trying to comprehend this stuff, tis a steep learning curve for me!
    previously on "thermo fan wiring"
    MOS posted the followfin in this thread
    The sensor in the bottom of the radiator on a hydraulic fan setup is... well.. a sensor and not a switch.
    You could use a jaycar voltage switch kit with a series resistor on the rad sensor to give you an adjustable thermostat.
    As an aside, many factory water temp SWITCHES are fitted in the bottom tank of the radiator, so replacing the sensor with a switch should not be a problem as long as you pick a sensible temperature.
    So does the 7m rad have this sensor and will it be compatible to be removed and replaced with a thermo switch?
    if you have a multimeter you can test the wires in your fuse box, or the ones on the back of the key barrell and tap off that source. i hate wiring, but its really quite straightforward once you sit down and play with it.
    JZA80 Convert Backyard Mechanic
    I suck at wiring, but if you want to have a squiz at my setup to give you some clues you are welcome. It's far easier working out what the diagram says when you have a working example in front of you to compare to! I'm running pretty much the same setup, 7m-gte with EL thermofans. PM me.
    Junior Member Grease Monkey rick q's Avatar
    Simplest place to find a power feed that's switched when the ignition is "ON" is the back of the cigarette lighter. It's generally just a matter of removing the lighter and tapping in to the connection behind. It's also a circuit that can take a bit of load - provided you don't use the lighter!!
    Cheers ..... Rick Jones
    Fraser Clubman
    FYI - i've updated my thread with the pic reloaded
  1. Wiring thermo fans to run directly off alternator
    By Ribfeast in forum Tech and Conversions
    Last Post: 22-03-2007, 06:46 PM
  2. Wiring up thermo fan through microtech LT8
    By WHITCHY in forum Tech and Conversions
    Last Post: 23-01-2007, 10:15 AM
  3. Wiring Experts! Seperating looms for engine swaps?
    By jeffro ra28 in forum Tech and Conversions
    Last Post: 29-08-2006, 06:29 PM
  4. Microleb wiring assistance on 1JZ!!!11oneone!!11(LTX-12)
    Last Post: 23-05-2006, 11:27 AM
  5. 100kW 4AGE wiring diagrams
    By Hen in forum Tech and Conversions
    Last Post: 15-04-2006, 06:03 PM
