Results 1 to 13 of 13
Thread: Wiring thermo fans to run directly off alternator
    Default Wiring thermo fans to run directly off alternator
    Hi guys, just wondering if there is any harm in running my thermo fans directly off the alternator instead of the battery?
    244rwkw / 328hp @ 18psi
    Default Re: Wiring thermo fans to run directly off alternator
    No but make sure you use a fuse to protect the theros and the alternator.
    Victoria, Mt Macedon
    Your alternator (fat white wire) is connected directly to your battery +ve terminal (through a big fuse).
    So I see there being approx zero difference.
    Any reason you suggest this?
    Hen
    I think I am getting some losses through the power cables on the way to the battery via fuses boxes etc (18yo car). Plus the battery is in the boot. I have a 60A fuse on the fans, might go smaller actually. Someone said it might create a greater load on the alternator or regulator, but I can't see how? The alternator becomes the main voltage and earth point for the car while it is running right?
    90% of fans i wire goto the alternator
    12 inch or smaller fans will draw less than 20 amps and startup and probably 10 or 12 at running speed
    i have a 16 in thermo and headlights dip when it turns on
    i have run fater cables for pos and neg vbut it still does it
    think its just the initial hit that does it
    nothing u can do about it
    maybe get a massive alternator but then u still have to spin it faster
    spinin an alternator faster at idle gives better charge when idling
    but recently had a guys car where the belt was slipping with a new smaller pulley
    so fixing one prob caused another
    Montrose
    Also, where are you taking the 'sense' wire from?
    Great info man Fans now wired directly to alternator. Voltage out of the ciggy socket still gets as low as 11V though, seems to happen after the car has warmed up a fair bit. Maybe the regulator in the alternator is getting heatsoak?
    Have you come across any aftermarket alternators for 1JZ?
    When my car is running again I am going to do some logs but my microtech shows that sometimes under power it goes down to about 12.0v instead of around 13.8v. Near new battery. Would this be pointing me towards a dieing alternator or simply too much current being drawn while under power?
    QUICKEST 1JZ'S IN OZ
    checking voltage through a cig socket is a waste of time, you will always have a lower voltage at the socket.
    chris - if your voltage drops under hard accel, your belts might be slipping
    Why would it be lower? Where should I tap it from, directly off the alternator?
    Do the 1JZ alternators usually only supply 13 volts or more when above 1500-2000RPM?
    all big thermos will drop voltage for abit
    is it droppin more than a voilt or are u just worried for nothing
    leave the multimeter on battery and see what voltage drops when fan turns on
    then maybe check the battery into the ign switch as thats the most important power feed
    see if that drops
    alt should chagre 13,5 to 14.5
    battery when running should be over 12.5 thats ok
    maybe there is not problem and yr just worried for nothing
    and who gives a rats ass bout the cig lighter
    its yr battery that needs the voltage not yr cig lighter
    another thing to check is ign wire on ign switch make sure there is no more than .5 volt difference between batery and it
    id hate for u to rewire yr whole car just because yr cig lighter is fuct heheheeheh
    Starts off around the high 13s when I start the car in the morning. When the idle drops to a normal level and the car is at operating temp, it drops into the low 12s. Then if I sit at the lights for more than 30 secs it drops into the mid to low 11s. Goes back up to the 13s depending on revs, but whenever I sit still it is in the 11s after that. Car starts first go every time, and everything runs fine, just wondering if I should be worried about the alt or batt etc.
    I might rewire my gauge to measure off the batt directly
    Feb 2007
    nt
    do not under any circumstances wire a thermo fan to the alternator unless you want to cook any voltage sensitive device. a fan will work just as happily as a generator when air flows over it but does not have the advantage of being regulated so you will feed random voltages into your wiring system. Manufacturers go to extreme lengths to stop this using zenner deiodes and more commonly relays with internal diodes. ask anyone who has had the problem of their aircon clutch energising intermittently due to welded relay contacts. this is not a good idea, den.
    to be old and wise first you must be young and stupid
  1. Replies: 2
    Last Post: 04-06-2007, 03:32 PM
  2. thermo fans. new TFS, having issues :(
    Last Post: 24-02-2007, 05:20 PM
  3. Wiring an 18RG/EU Alternator
    By Spectre in forum Tech and Conversions
    Last Post: 21-11-2006, 10:57 PM
  4. Thermo fans
    By Ghetto-AW11 in forum Tech and Conversions
    Last Post: 08-08-2006, 02:07 AM
  5. Replies: 0
    Last Post: 07-02-2006, 01:01 PM
