i had a 1.00 rear housing. boost started at 2600 from memory, its been a couple of years now since i sold it off.
what A/R housing you have on the back ?
What rpm was it starting to boost at?
Just curious.
8.3 et PB 169 MPH PB
Shane: I don't know why but your setup always seems to be a lot more responsive than other people's. Don't know if it was the tune, the fuel, the weight of car or whatever but as you know I had a .9 a/r turbine on my old turbo (unsure of diameter wheel) and it was laggy as hell. Not many people could get away with running a 71mm turbo on a 1j for some reason.
the TO4R was great
the GT51R with the 71mm front wheel, first gear was crap onthe street only made 7psi, second and third gear were fine though.
Convertor helps heaps though doesnt it Shane? As far as sorting out lag issues.
11.72 @ 116.7mph = Quickest Stock Turbo Jzz30 series SoarerAnd 1st into the 11's
WOOOT!!!
Still going good![]()
of course.
it would be pretty dumb to whack on a single turbo and not get a convertor to match.
Ezras a lying hoe bag.
(edit)
I run a GT3540 with the 1.06 rear on the 22R-E. I think it's too big for the 2.4L, but I don't have the rev range you all have with your 1J's. I'm going to try the .86, see if I can get on boost a little earlier.![]()
1986 RT-142 Corona. Taking the phrase “WTF”, to a whole new level......
PHOBIA. Fear of.........investing your soul into customizing a "f@#kin what" a Corona???
Click to see PHOBIA
wait until it goes on the dyno and you have to start pulling shitloads of timing out to stop it pinging above 5k.Originally Posted by EldarO
(ill elaborate further if you need me to)
linden
Originally Posted by WHITCHY
I don't even have a vested interest but I'm curious, can you please elaborate anyway Linden?
when you run a small turbine housing on a large engine it will get an early spool but the problem is it will start to choke up at some point later in the rev range.
when it chokes up it will increase exhaust manifold pressure and reduce the amount of used exhaust gasses that can escape from the cylinder (+large amounts of heat buildup) and it will contaminate the intake charge for the next engine cycle.
the only way to then stop it from detonating will be to either reduce boost or pull a shiteload of timing out.
thats the quick way to explain it and i could explain further but alas i dont have the time.
linden
Yeah a .63 housing sounds way too small for a 3L engine. 1.06 is about spot on IMO.
Norbie!
www.norbie.net
1.06 is a good allrounder for a 3L but a .82 could also be good depending on application ie: drifting where throttle response is of main concern.
the only time id use a .63 on a gt35 would be on a 2L engine with small cams.
linden
Originally Posted by The Real Roadrunner
add a blower to the equation and and you can run the same boost at the manifold with around half the exhaust back-pressure. it should also run much cooler![]()
thats the theory anyway
hello
I've heard of great results with a .86 rear housing. very early spool, and just enough huff to get it through.
I was happy to go the free-er flowing 1.06. with 3L and vvti, lag is not a massive issue![]()
