Results 1 to 11 of 11
Thread: FPR issues... Zero Preassure?
    -Street Drag Machine- Grease Monkey renxun's Avatar
    Jan 2007
    Sabah
    Default FPR issues... Zero Preassure?
    Was on my way taking up a drag challenge 18miles away from my home... drove around 2miles out of my house and my car start to jerk and then noticed that my fuel preassure drop to ZERO..my car dead by the roadside.. first i thought was my fuel pump had died on the spot but later i heard swooshing sound of fuel flowing....and both my pumps are running fine... however my preassure still zero....when i squeeze my return hose , to reduce the flow my car was able to start again .. and when i release my hose my car died again....
    is there such possibility the FPR will fail and dun have any preassure at all ...? or issit merely my fuel pump are weak?
    Drift Drift Drift and drift untill getting high fever...
    Default Re: FPR issues... Zero Preassure?
    if you can here fuel pumps running and you have no pressure the pump failure is most likely, what sort of vehicle and engine?
    corona with a 1jz.
    IIRC he has two pumps. if one failed there should still be pressure I would have thought. Probably enough to drive normally but maybe not enough under acceleration.
    QUICKEST 1JZ'S IN OZ
    Junior Member Backyard Mechanic jezza323's Avatar
    could be that the FPR is jammed open...so the fuel is just pumping straight back out to the tank...
    has no Toyota anymore :( Conversion King tooch's Avatar
    Don't completely rule out a fuel pump failure. Replaced one in my mate's RB20'd Rodeo on the weekend, the old pump still ran, and the car would run, but had random misfiring and jerking, and drove like shite. Very little fuel pressure (verified by a gauge), replacing the pump fixed the problem
    Jan 2007
    Sabah
    not only i heard the pump running... i can even hear the fuel flow from my engine bay going pass thru the fuel rails and returning back. im asking my mechanic to come over my house for a check up ... .tow the car back to my home yesterday night.... around 100 frm home the towing rope snaps... fu(k it have to push my arse off back to my home..
    FPR failure is unusual but certainly possible. If there is fuel flowing back through the return and the gauge reads zero, FPR failure seems most likely - if the pump was faulty you'd either get zero flow or some amount of pressure in the rail.
    Jan 2007
    Sabah
    damm it.... i changed to another FPR today .. stock also ... i have one laying at my store.. replaced it... tis time no return fuel.... damm! my fuel pump get heated up ... and screwed when it stop spinning.... replaced 2 new pumps.... and it start to get heat again ... thought it was somewhere clogging ... only to find out that the FPR that i changed was actually jammed shut... wtf..... tomorrow gonna get new adjustable type and see wat happen next ... really in a mess as i opened up alot of things that i thought might possible happen from injectors wiring,fuse box,ecu connections ,surge tanks to see any clog,filters up to the component inside the ecu but to no avail... and it seems that little culprit was the stupid damm FPR... wasted my whole day though
    Montrose
    Do you have an inadequate filter that's allowing dirt to do funny things to the reg?
    Western Aus
    ok, so you had a fuel reg that was jammed open...
    then you replaced it, and that one was jammed shut?
    wow... cant seem to catch a break! unlucky!
    Elmo.
    Jan 2007
    Sabah
    manage to start the car and not long after that ... it died again ... WTF.... thought there must be something wrong with my ecu... might be a short circuit or other shit.... checked again all the harnes from the power supply -fusebox-ecu-injectors n ignitors-coils.... done that for around 1 n half day... then my friend told me... hey ... ur cam/crank sensor wire clip was open up .... went to check ...true enough, the lock key has broken, no signal from the sensor thus ecu dun let my car start.... damm it... at least i learnt something today
  1. removing driveshaft issues
    By 4agte in forum Tech and Conversions
    Last Post: 27-02-2007, 09:50 AM
  2. 3VZE V6 Head Gasket/Overheating Issues
    By Toyo Truck in forum Tech and Conversions
    Last Post: 03-09-2006, 08:30 PM
  3. GZE Aftermarket comp issues
    By craigy in forum Tech and Conversions
    Last Post: 17-01-2006, 10:45 PM
  4. 100kw in AE82 Idle Issues
    Last Post: 11-01-2006, 07:15 PM
