Page 27 of 36 FirstFirst ... 172526272829 ... LastLast
Results 391 to 405 of 531
Thread: Toyota's Interchangable Oddities.... (TIO#)
  1. #391
    oregon
    Default Re: Toyota's Interchangable Oddities.... (TIO#)
    well not a Toyota oddity... BUT it is an interchange... it appears that AE82, AW11, ST165 all can use the same rear fixed pillowball mounts from Cusco. There are a few other interchanges that most folks don't know... I found this link yesterday... Cusco part # short description... and pricing. For the ENTIRE Cusco line(not just toyota.....)
    http://www.cartronicjapan.com/CUSCO_...ist_header.htm
  2. #392
    Aug 2006
    Selangor D.E.
    Just a note on the Altezza 1gfe exhaust manifold ... won't fit a 1ggte.
    It's like 3+3 instead of 1ggte's 2+2+2
    This is the 1gfe water pump, if all 1g series block are the same then it will fit 1ggte. Metal gasket.
    The 1gfe cylinder head gasket, same as 1ggte, metal and thinner. will increase compression.
    The piston and conrods are light, with a lightened crank, these stuff will be good for a high revving 1gge. But I didn't take any photo or weight them.
  3. #393
    Canada
    Can you measure the thickness of the head gasket?
    I tried a similar thing with a 5E-FE, i used a late model thin metal headgasket to replace a conventional composition headgasket (IIRC, 0.25 mm copper, single layer).
    Under some circumstances (drop throttle decel) there was extremely slight contact (piston to head) at the squish areas.
    Measurements would be nice.
  4. #394
    Aug 2006
    Selangor D.E.
    I don't have a caliper, so this is what I have done for you ... maybe about .5mm?
    I don't know whether it helps, as for 1ggte, the valves and pistons won't knock.
    Then I assume you must be very careful if using adjustable cam gears
  5. #395
    Canada
    Thanks!
    That's nice, it shows that it is a multi-layer type metal gasket.
  6. #396
    The Supreme Backyard Mechanic
    xUZ and 1gzfe share the same flywheel, haha... Don't know how many people that will helpthough.
  7. #397
    Old School Cruiser 1st year Apprentice Pieman's Avatar
    KE30/35/55 leaf shackles are a direct swap for KE20/25 etc. You will need the KE30/35/55 bushings for it to work (the pins are thicker but the shackle hanger and leaf spring eye are the same size as ke2x). Useful when the pins are rusted out and a nice little upgrade.
  8. #398
    TAS
    FYI:
    * Aftermarket AE86 control rods fit xA6x Celica with NO modifications
    * Whiteline MA61 front adjustable swaybar fits xA6x Celica with NO modifications
    See xA6x Celica: AE86 castor rods and Whiteline MA61 adjustable swaybars fit perfectly!
  9. #399
    Junior Member 1uzfekp60's Avatar
    Sep 2007
    NZ
    Not sure if this old news.
    ST141 front crossmember is a very close fit into a KP60 (file out the holes about 5mm each) . The front supports (anti-roll bar) will bolt up to the chassis rails. This also gives about 20mm wider track each side.
  10. #400
    nuts Grease Monkey
    auckland
    ke3# crossmember same width as ke2#, two bolts need slotting 5mm, the lower arm pivots are wider than ke25 so will give bit more camber, even with the shorter ke30 lower arms. suitable when doing alot of customising of engine mounts etc and gives better option of rack conversion in ke2 rollas due to wider lower arm pivots, (ke3 not as wide ke7 pivots tho)
    -Mark
    E2 + E7 fan
  11. #401
    Side repeater indicators from '83-'97 hiluxes fit onto MX73 Cressidas (and probably lots of other cars)...means clear indicators from ebay like these also fit onto the Cressida. (Direct bolt in and plug in no mods necassary).
    bit ricey, but they are cheap !
  12. #402
    Jun 2007
    UK
    Quote Originally Posted by 5000gt
    would this cover 1g gte as well
    Group A 7M MA61
  13. #403
    Quote Originally Posted by groupasupra
    No - The 1G GTE is a 6 bolt pattern and the 1UZ is an 8 bolt.
  14. #404
    How close is the ST141 to an RA2# with that sub assembly?
    Hello.
  15. #405
    no backyard Domestic Engineer japlish's Avatar
    this is a good cheap brake upgrade for ke70 owners:
    stock ke70
    mz10/mx73 struts with king springs
    sigma lower arm
    ra40 tie rods
    ra60 P/S arms
    flip the spring upside down on the strut, use the stock ke70 spring perch and top hat, bolt it all in!
    P.S you have to wind the castor out as far as you can (forward) to clear the spring inside the tower!!
