RT133/130 corona struts fit RA23/28/40, and you can either use with 2 piston sumitomo callipers (works great) or the 4 piston hilux pots with the pugeot vented rotors.Originally Posted by 1GT04
see very first post in threadOriginally Posted by 30psi 4agte
../delete/ban
tech moderator
sprinter {ae86} bonnet latch fits the gz/mz20 etc. just need to use a bolt and nut for the bottom hole and the secondary latch handle is a little shorter but can be used that way or extended.
7ag head gasket is metal shim and fits the 4ag!
yeah m8 did see it but there is alot of people on this thred that have said they do fit.Originally Posted by ed_jza80
Just thought i should clarify the matter![]()
ae86, gz10 and ga61 have same map sensor
-Mark
E2 + E7 fan
None of those have map sensors dude.
Ohhh thats hilarious, thanks for the new signature boys!!
maybe not in your country! our ae86 have 4ages.. our gz10 have 1geu or 1gge and our ga61 have 1geu or 1gge. the jdm ae86 are map sensor bigport bluetop and the 1geu are jdm lasre or mk11 version (something like that) they're map sensored NOT the afm version. the toyota epc doesnt usually lie
part number 89421-12020
-Mark
E2 + E7 fan
CrUZida getting ownd, add that to the sig Ace
Originally Posted by skiddz
Pics to prove the Gen1 1GEU and 1GGEU have map sensors please.
The gen3 1GGEU runs a map sensor, but that was inthe GA70 Supra, not the GA61 or GZ10.
Indeed. All early 1GGEU's and 1GEU's i've seen including two JDM GA61 Celica XX's had AFM's. I've got a Gen2 1GGE that has MAP though, but as CrUZ said, that was from a GA70.
I do remember someone stating that they have seen a GA70 with a factroy 1GEU in that.
So its possible that that 1GEU runs a map sensor, just like the 1GGEU of the same era.
cant be too sure, just going off the epc. tho ive seen plenty map sensored 1geu mainly in gx71 cressida. will take a closer look next time at pick-a-part![]()
-Mark
E2 + E7 fan
Must be a date thing.
Sort of pre 85 they ran AFM, post 85 they switched to map.
99% of GZ10's and GA61's will be pre 85 though.
GS123 Crowns, GX71 'Cressidas' will be both pre and post '85
