Page 29 of 36 FirstFirst ... 192728293031 ... LastLast
Results 421 to 435 of 531
Thread: Toyota's Interchangable Oddities.... (TIO#)
  1. #421
    Sheebz Automotive Grease Monkey Gleno28's Avatar
    Default Re: Toyota's Interchangable Oddities.... (TIO#)
    While we're on the hot tips, the 18R is a much older and heavier engine. I tried to put an 18RG in my old st141 many years ago, almost fits, length and width good, even with 22R cross member, would require changing of the steering setup, engine mounts, box etc. Definitely not worth it mate, maybe try putting some extractors and a webber on for more grunt.
    Glen.
    A lone crusader, in a dangerous world of low reputation...
    ST141 Corona, VZN130 4Runner, 4AGE KE70 Pan Van
    18RG RA28
    1GGZE RA28
  2. #422
    Swap in the RT142 front end... 22RE will be a much better choice. Plus all the bits from the RT142 fit. Better yet, polish the ST141, sell it and buy an RT142.
    Oh, and a new thread would have been a better option.
  3. #423
    Sydney N.S.W
    For a ra28 brake upgrade.
    can you use the XT130 strut and then use the ra28 hub instead of the xt130 hub?
    then the pug/ hilux gear.
    Are the hubs the same or do they change offset in some way?
  4. #424
    Quote Originally Posted by Omegaman
    do not post questions in this thread, keep this thread on topic please
    no you cannot use the ra28 hubs for this upgrade
  5. #425
    Tasmania
    96 camry abs speed sensors fit into the hub of an st205, the angle the wires come out is slightly diff, and you have to cut and shut the wiring just after the sensor (as the hard lines are completly diff shape) but yeah works a treat.
    i only tried the front but back should work also.
    1973 TA22
  6. #426
    Aug 2008
    Tasmania
    Thanks guys, you've convinced me. sorry about the thread, my bad.
  7. #427
    Western Aus
    Quote Originally Posted by 7M-GTE MX73
    Side repeater indicators from '83-'97 hiluxes fit onto MX73 Cressidas (and probably lots of other cars)...means clear indicators from ebay like these also fit onto the Cressida. (Direct bolt in and plug in no mods necassary).
    bit ricey, but they are cheap !
    LN86 is the chassis code your after. i think LN85 is same same, but cant confirm.
  8. #428
    nothin' doin Grease Monkey
    1G's use the same spigot/pilot bearing as 4A's.
    makes life easy if your spare parts place doesn't have a listing for a GZ20 or a GA70
    Quote Originally Posted by Rex_Kelway
    i am of no speech
  9. #429
    Banned 1st year Apprentice
    south australia
    i discovered that jza80 front suspension fit beautifully into an a70 with no mods
    Ryan
  10. #430
    I am not yet a Grease Monkey RA23's Avatar
    Fast idle valve from 2S-E (SV11? Camry) is identical to 18RGEU item.
    Projects: No project cars left ...
  11. #431
    Guys can anyone tell me what brake mastercylinder is interchangeable with an RT81 1973 Corona,its a 2 bolt horizontal design.
    Nath
    -Just Alloy Radiators-
    www.alloyradiators.com.au
  12. #432
    bolt spacing please
  13. #433
    I have just managed to fit the internals of 4.3 to 1 MKIII supra LSD into my MX83 cressida open diff housing. Other than being a bastard of a job it's all interchangable.
  14. #434
    Toymods Club Member #274 Backyard Mechanic Rallystanza's Avatar
    Quote Originally Posted by RiceburnaGTV
    Nath
    If its the model im thinking of with the 2 reservoirs for fluid, then that maser bolts into sprinter. So, if thats the case, then you can run a 15/16" master from a NON ABS R32 Skyline. Will more than likely need the hard lines to be changed/adjusted to suit. You wouldn't want to run the Sprinter master as its too small as if i remember correctly, the Corona master is 15/16" or 1".
    Can anyone help me finish this riddle?? Just unsure about the corona master in question...
    Jez
    R.I.P Peter Brock.
  15. #435
    Robots! dancing robots! Domestic Engineer gearb0x's Avatar
    One for the 4age 20V owners, I've been looking for a TPS for mine, GT told me a 2JZ one would fit but I think they are almost as hard to find as 20v ones, I found this posted on the internet:
    "4AGE 20V silvertop TPS part number is 89452-12080 which is the same as 2JZGTE, 3RZFE, 2RZFE, 5VZFE -> 89452-12080 / 22080. Not quite sure about Blacktop TPS number, will get it later."
    Just picked my self one up off a 2RZ and its perfect (89452-22080). The 3RZ one they had was too small
    Regards,
    Phill
