Page 33 of 36 FirstFirst ... 233132333435 ... LastLast
Results 481 to 495 of 531
Thread: Toyota's Interchangable Oddities.... (TIO#)
  1. #481
    Default Re: Toyota's Interchangable Oddities.... (TIO#)
    Distributor plug off a 4AGE 20v, anyone know what other toyotas use this plug?
    Toyota Car Club (Qld)
  2. #482
    New Zealand
    Giot a pic of the other side of the plug? Looks very much similar to a plug on the 5S-FE loom I have from a Corona.
    Callum
  3. #483
    Aug 2011
    looks similar to the ignitor plug on my 1uz soarer
  4. #484
    May 2011
    does any one know how to get st205 front brakes to fit st185 with out using a smaller diameter rotor?
  5. #485
    Aug 2011
    is there any IRS rear end that is interchangable to a xt130 corona easily??
  6. #486
    Sep 2008
    Vemmelev, Denmark
    Quote Originally Posted by takai View Post
    Oh yeah, jogged my memory somewhat.
    4A FWD reduction starters fit T50s fine.
    AE95 axles are the same as kouki AE86 T-series, but are 4x100, which makes them near useless.
    I know this is an old thread, but can anyone tell me which 4A takai refer to, is it 4A 8valve or 4A-fe/4A-GE
    Thanks
  7. #487
    Low rep Grease Monkey
    Apr 2010
    bkk
    interesting stuff
  8. #488
    Dec 2008
    Lancashire, UK
    Quote Originally Posted by cultus View Post
    This is the 1gfe water pump, if all 1g series block are the same then it will fit 1ggte. Metal gasket.
    The 1gfe cylinder head gasket, same as 1ggte, metal and thinner. will increase compression.
    The piston and conrods are light, with a lightened crank, these stuff will be good for a high revving 1gge. But I didn't take any photo or weight them.
    Justmy 2 pence worth on the 1ggte, 1gfe stuff.
    The 1gfe headgasket will work, using it myself.
    I good upgrad for using standalone ecus is use the front engine plate from the 1gfe, allows you to fit the Lexus water and oil pumps (easier to get over here as a newer engine), but also now gives you a crank position sensor so you can use 1gfe coil packs for direct coil on plug ignition instead of dizzy.
    Hence why the water gte water pump wont fit the fe.
    The blocks not a lot different but the gte has the oil return, the fe doesn't.
    Lexus alternator will also fit.
    IS200TT.co.nr
    The Evolution of my 1GGTE Turbo Lexus
    Please leave your comments.
  9. #489
    Jun 2012
    mexico
    anyone knows wich power window setup its same to the MA61??? need that info, thx.!
  10. #490
    Not 1005 sure, but the MA70 Supra has the old fashioned powered regulator arrangement as opposed to the later cable drive arrangements, worth a look.
    MS51Crown Coupe,
  11. #491
    Junior Member Grease Monkey stealth's Avatar
    Jul 2012
    For anyone playing around with a60 Celicas and JZs...
    Crossmember from ST141, RT142 Corona fits SA63 and RA60/65 Celica respectively.
    this R engine-d crossmember can be used with these mounts: http://www.xcessivemanufacturing.com...step=4&pid=284 to fit a JZ into a 60 series Celica.
    As far as I'm aware MA61 Crossmember does not fit xA6x Celicas suitable for JZ-ing. Celica Supra engine bays are a good few inches longer than 4cyl Celicas.
    SA63 auto tailshaft fits rear of a W55, so I assume all alloy W series.
    JZX90 radiator can be mounted into SA63 with custom mounts, the cores are the same size. Mounts are different, but rad mounts aren't hard to make/mod. Nolathane sway bar link bushes are your friend.
    MX73 aftermarket coilovers fit A60 Celicas.
    more to come as I play around
    JZA63 Celica 13.9 @ 162km/h
  12. #492
    Feb 2012
    Australia
    Quote Originally Posted by stealth View Post
    Does this mean they will fit RA40 aswell? RA60 struts fit RA40 with no issues that I'm aware of.
    My Daily: NooB's Delivery Vehicle
    My wife's Daily: Series B RA40 Liftback 22RE, power steering, AC. Cushy as.
    Current Project: NooB 3TGTE swap
    Back Burner: 1964 Toyopet ToyoAce, and a Series B TA45 GT coupe
    Too many cars
  13. #493
    Jul 2012
    Quote Originally Posted by MarcusEstevez View Post
    The aftermarket ones are weld on, gotta use original hub. So its sorta already a custom job, top mountings shouldn't be a problem.
    http://www.celicasupra.com/forums/sh...MX73-Coilovers
    As far as I'm aware, the supra top strut mount is the same fitment to a60 Celicas, not 100% though.
    [EDIT] just confirmed the only difference between MA61 and RA60 struts is the kingpin angle, irrelevant for fitting A/M units.
    SO! if MX73 coilovers fit MA61 (100%), no reason why they shouldn't fit A60 celica, and according to you, A40 too!
  14. #494
    Feb 2012
    Australia
    Thanks for that =)
    Too many cars
  15. #495
    Jun 2012
    mexico
    "Z" UTE thx about that, but i forgot to say that SUPRAS in my city arent allowed... so any other car that came with the same MA61 power windows setup?
