Page 31 of 36 FirstFirst ... 212930313233 ... LastLast
Results 451 to 465 of 531
Thread: Toyota's Interchangable Oddities.... (TIO#)
  1. #451
    Default Re: Toyota's Interchangable Oddities.... (TIO#)
    Be very careful saying 'corona avanti' chuck, some are irs and the disk brakes on them are no good to nobody. Find an st141 with a live axle with disk brakes, these are on non-irs avanti and some cs-x i think
  2. #452
    Quote Originally Posted by old_school_jap1 View Post
    Thanks mate, has been a lon long day, have edited my post to reflect ST141, yes I have also found these brakes on the CSX, but definately not on the CS( crapspecial).
    cheers Chuck.
    MS51Crown Coupe,
  3. #453
    Victoria, Mt Macedon
    NB, the Corona discs WILL NOT fit on a TA22 diff. The wheel bearings and bolt spacing are smaller than those on the Corona. The best option is to find a RA23/8 housing, which bolts into a TA22, and to which the Corona discs fit. It's been a couple of years, so I'm a little hazy, but I know it won't fit directly.
    Hen
  4. #454
    Hen, funny thing is I have a TA22 diff fitted with the Avante brakes! The early TA22's with the "D" series diff may be a different kettle of fish. But I have successfully done this brake upgrade on an RA23 as well as the TA22. They also fit the "F" series from the MKII Corona.
    cheers Chuck.
    MS51Crown Coupe,
  5. #455
    Normally Aspirated Domestic Engineer RT104GT's Avatar
    Quote Originally Posted by "Z" UTE View Post
    The most easily obtainable disc brake conversion, and one with minimum hassles, is the entire brake setup from a ST141 Corona Avanti. You will have to press the bearing off your axles to install the new bearing retainer plate. Press on new bearing, install new sael, have some new brake lines made up, and last of all have some new frrules placed on the handbrake cables. No such thing as a bolt on conversion in my opinion, as there is always something that needs to be made.
    cheers Chuck.
    I wrote an article on making up a 2/3rd circlip to fit the gap in fornt of the bearing negating the need to destroy the bearings and repress them.
    My Corona GT has has these on for over 3 years. QEd.
    1968 RT40S Corona 1600S series II (restore in progress)
    1973 RT104-MQFG 012604 Corona GT JDM (Owned since 1976 242000 km)
    1989 ST185-BLMVZ-0007199 Celica GT4 JDM (unmolested classic 95000 km)
    2012 ZN-6 86GT (shed find 5000 km in 6 years)
  6. #456
    Quote Originally Posted by hks7mgt View Post
    Been reading thru this post and could not find any reference to what rear disc brakes will bolt onto a TA22 rear end. I was told that the MA61 and the RA40 GT discs would bolt straight on.
    Can someone confirm this?
    Not that I remember. The RA 40 axle is different.
    I had to wait years to fit the avanti discs to by Corona rear end.
    Nothing I looked at in the TA days fitted.
  7. #457
    Jul 2008
    Does anyone know if the vacuum advance distributor from a 5MGE will fit into a 7MGE??
    I feel sorry for people who think cars are simply for getting from A to B
  8. #458
    Nov 2007
    Thanks To postfach for the following, he found out that the 1jz and 1g-gte air con ports can be swapped.
    http://z20soarer.org/forums/showpost...6&postcount=20
  9. #459
    Jun 2009
    Quote Originally Posted by rex_hvn View Post
    just wondering if a 22RE intake manifold fits onto a 22R head?
    it does,I replaced a head on an RA65 celica (22RE) with one from a hilux (22R carby) about a month ago. the head is exactly the same,only the pollution gear and it's fittings vary between models.
    Justin...
  10. #460
    Junior Member Backyard Mechanic cptsideways's Avatar
    Dorset
    Z20 Soarer window motors fit LC80 Landcruiser front windows I found out today
    Sliding his D1 Soarer around the UK
  11. #461
    Apr 2007
    wilcannia NSW
    the gearbox from a BU36 ( and possibly others. ) dyna can be fitted with the lid from an H55F. giving you a 2wd floor shift overdrive light truck box. the stick position is well forward. good for things like F100s.
  12. #462
    Junior Member 1st year Apprentice moggie's Avatar
    Feb 2009
    Can use Toyota 2M rings for 1GGTE Gen3 with ring measuments;
    Compresion ring 1 = 1.5mm
    Compresion ring 2 = 1.5mm
    Oil RIngs = 4mm
    Set of 6 Chrome moly rings set me back $100
    SA63 Coupe Restoration - Finally have the motivation to finish her.
  13. #463
    Carbon neutral Carport Converter Jt_70R's Avatar
    Here is another one for this thread.
    ST162 strut tops are very close to MX83...
    Below is a ST162 KMAC camber top bottom ring, (upside down) showing the fit to my MX83, second photo shows the small amount of filing I had to do. Probably around 1~2mm.
    Thus ST162 strut tops should* fit X83 with a minimum of filing.
    * Note: standard strut tops from ST162 into X83 would probably require slightly more filing due to the larger diameter studs used compared to the KMACs. I have not personally swapped stock strut tops, only my KMACs. However PCDs and bolt spacings beween the two chassis are pretty damn close.
    This probably isnt really the most useful swap out there for most people, but hey my x83 now has some nice camber thanks to my old 162.
  14. #464
    auckland
    Done a bit of research on Toyota hubs / bearings / brakes for 80s RWD cars.
    According to Toyodiy, the same part number for front wheel bearings/front hubs/discs/calipers are used on:
    MZ10 soarer
    TA63/AA63 Carina/Corona/Celica
    GX61 Cressida
    So handy for finding replacements if need be.
    Only applies to the struts with vented discs.
    The same wheel bearings but different hub part numbers are used on:
    GX71 Cressida
    Townace van (Cant remember model number, but from 80s right through 90s is same bearing part number)
    Some trolling through pickapart revealed that the townace hubs have the mounting face of the disc further from the strut and closer towards the mounting face of the wheel. So you can fit a thick disc to the back of the hub, with space left to mount a caliper to the strut.
    I was able to use a Citreon Xantia turbo front disc with an SW20 front caliper to give a pretty decent sized front brake setup that still (barely) fits under a 15" wheel, and doesnt widen the front track at all.
    Using the van hubs could also mean that there's possibly a 4 pot brakes solution that bolts to the back of the hub also, that would give more space to the spokes of the wheel without the need for spacers.
    Keen to try this at some stage, as 4 pot setup is a shite load lighter than steel twin pot + bracket + spacer!
  15. #465
    Junior Member Carport Converter ecko's Avatar
    May 2007
    tasmania
    7m and 1jz valve cover gaskets are interchangable
