Results 1 to 7 of 7
Thread: 1ggte compression test
    Junior Member 1st year Apprentice Spindevil's Avatar
    Feb 2007
    Default 1ggte compression test
    did 2 compression tests on the 1g today.
    one with injectors wired up (i'll call it wet) and the other w/o injectors wired up (dry)
    both tests were done with throttle wide open and each cylinder was tested for 10 cycles
    pressure was measured in psi.
    i got some very odd readings and would like to know if anyone has an idea of what the readings are supposed to be?
    Cyl wet dry
    1 160 170
    2 170 170
    3 160 175
    4 180 195
    5 185 195
    6 185 195
    any input would be helpful thanks
    1990 aerotop supra 1jzgte manual,
    1990 aerotop supra 7mgte manual stripped
    2003 ba xr6turbo - top to bottom build.
    Default Re: 1ggte compression test
    Double check them.
    Make sure they dont go beyond those pressures (ie, after 10 cycles).
    A wet test is usually with a teaspoon of oil, not squirts of fuel...
    If they are correct readings, cyl 1, 2 & 3 are worn, nothing odd about that, its called the effects of a turbo.
    If you sig is referring to this engine "the cloud machine", then isnt it exactly what you expected?
    Feb 2007
    more or less
    but not what i wanted
    just got together most components for my single turbo conversion
    looks like a conversion is on the cards tho
    Feb 2007
    i actually suspected the problem would be valve stem seals
    but worn rings was my #2
    Feb 2007
    was hoping it was just blown turbo
    a- you do a dry test first
    b- you use oil not fuel
    the dry figure should be lower than the wet... so those numbers are meaningless
    if you had rings going off due to lean-out, they'd first show in #1 & #6 as they're the two cyls most likely to see less airflow - paricularly if you've removed the TVIS system. And you'd see a greater difference between the dry & wet test for the cyls with issues.
    i'd suggest you re-test it properly.
    i did a dry compression test on my old 1g, that was in sujperb cond,
    it read 150psi over all cyl's....and i did have smoke probs from my turbs aswell, only when i would back off,
    blake
  1. Compression Test Results for 20v ST
    By Escy in forum Tech and Conversions
    Last Post: 28-02-2007, 11:42 AM
  2. Compression test results
    By minxgirl in forum Tech and Conversions
    Last Post: 16-11-2006, 08:05 PM
  3. 1ggte COMPRESSION TEST....readings.....SORTED!, cheers
    Last Post: 23-08-2006, 11:12 AM
  4. What do these compression test resaults mean...
    By doobs in forum Tech and Conversions
    Last Post: 13-06-2006, 09:41 AM
  5. 20v compression (compression test)
    By 2revup in forum Tech and Conversions
    Last Post: 20-03-2006, 06:06 PM
