Results 16 to 21 of 21
Thread: noisy injectors since aftermnarket ecu installation
    Default Re: noisy injectors since aftermnarket ecu installation
    Well if everything is setup right, you clearly haven't a loud enough exhaust.
    very true haha. no muff to tuff
    theres no hearing anything in mine, hard enough to hear the stereo 3.5inch of exhaust drowning everything.
    1 less muffler and i may aswel dump exhaust behind front wheel like ill be doing in my drag car
    S.A
    FWIW My injectors have always been overly loud too. When i had the 550cc in the were quite loud now with the bigger injectors its even worse.
    This is a guage of just how loud the new ones are. When i put them in i had to play around a bit with the fuel trim to get it started. the new injectors were so much bigger that the eng was getting flooded easily on crank and it took a few goes to trim up the map so that the thing would actually start.
    Anyhow. when i first cranked it over i could here what sounded like a cracking noise sort of like when i lead is off and the spark is arcing out. so i stopped cranking and checked the eng to see if a lead was off. I checked everything and could nt find any thing amiss.
    I then went back in the car started cranking and there was that noise again !!! I was like WTF is that. ........... It turned out that it is the F$$KN injectors opening and closing ,They are that loud that it sounds like a lead is off !!
    I am now thinking ...seeing im not the only one with this noise that it must be the way that The EMS ecu is configured to drive its injectors.
    I wouldnt be too concerned about it as i have always had it and have never had any probs with anything. IE injector life / injectors over heating /ecu faults etc etc.
    Conversion Master Grease Monkey Whiplash's Avatar
    wa
    Quote Originally Posted by Disturbed1
    how u gonna tell if 1s not running and the other 5 are ticking away like crazy shannon???
    easier to pick a dropped cylinder dont ya think
    thats why i said if ya get good enough!
    wa
    the ecu is possibly pulling them open harder with more amperage making the sound louder
    My Corolla ! - 4AGTE
    KP61 - 4AGE
    Sounds logical. With the resistor pack the injectors would be taking longer to open, which equals slower, which in turn equals quieter.
  1. late 97 on hilux 3rz turbo conversion walk through
    Last Post: 07-01-2011, 07:10 AM
  2. turbo kits for 3RZ-FE
    By ToDa30/4 in forum Tech and Conversions
    Last Post: 18-09-2006, 06:31 AM
  3. Which injectors for which 4AGE bigport ECU
    By Grega in forum Tech and Conversions
    Last Post: 04-08-2006, 06:49 PM
  4. 3rzfe engine wiring diagram 98 model
    By BeRad in forum Tech and Conversions
    Last Post: 12-07-2006, 10:17 AM
  5. Aftermarket engine management and injectors
    By benjamin in forum Tech and Conversions
    Last Post: 14-05-2006, 01:05 PM
