Page 1 of 3 123 LastLast
Results 1 to 15 of 37
Thread: NEW MOTOR fubar...crank keyways dmaged...HOW TO WELD PULLEY 2 CRANK????dodgy!
    Default NEW MOTOR fubar...crank keyways dmaged...HOW TO WELD PULLEY 2 CRANK????dodgy!
    hey guys,
    pulled down the front of the new motor to fit the NA cams and new seals all round,
    when i pulled the Timing belt off, the crank belt gear had 8-10mm play.....(turning on the crank)
    finally managed to get the fooker off, and to find the keyway is almost gone....damaged and crushed....
    the crank keyway hole has been opened up....
    tried putting the harmonic balancer keyway in the tbelt spot, and its a very loose fit...
    and the Tbelt gear keyway slot is fubar and damaged
    i dont know how this motor would have been running b4,....the timing would have been majorly out,
    is there anything that can be done to this mtr, while its still together?
    will get some pics up for tomoz night....
    Default Re: NEW MOTOR fubar...crank keyways dmaged....can it b saved?
    uh oh.. ...... the crank is gonna have to come out for welding/machining at the very least.
    thats what i was afraid to hear!.....but i knew i was gonna hear it, lol
    if its a SSS special take it back. From what i hear they are all too happy to fix / replace faulty gear.
    otherwise hows the crank on the old one? did that bearing score it?
    Black Betty >HERE!<
    (\__/)
    I bet it was from those hektic heli's you were doing.
    edit: ahh this was the new motor. Yeah take her back. Or get another bottom end.
    queensland
    fixable by specialist engine shops (like me). crank out
    nah its not an SSS...another import place, waiting for call back....probably tomoz,
    no chance of swapping cranks, other crank needs $$$$ spent on it,
    hectic hellis will come with the new motor aswell ( i dont learn ) lol
    Quote Originally Posted by terryo
    what would that cost, just out of interest, for arguments sake....
    oh, i thought you said "new" motor as in rebuilt, not shit second hand from dodgy importer.....
    what Terry said - remove, fix and re-install (and fit new bearings while you're there).
    or if it was a shitter motor, weld it on and never talk or do anything about it again
    i aint dodge, but if this were a 4k or similar yeah....
    wa
    i think what the machine shop can do is machine a new keyway 180 degrees from the old one and then just mrak the harmonic balancer with tdc marks again
    Quote Originally Posted by ecotechilux
    Wow lot of work.
    If it's a half moon key way just have it machined out to take a square cut key way. I've had an 18rg do the same thing.
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
    What about dowelling the timing pulley to the harmonic balancer?
    Jealousy is a curse
    Tallahassee, FL USofA
    http://yarchive.net/car/crankshaft_keyway_repair.html
    http://www.loctite.us/int_henkel/loc...sp_language=en
    The right bolt torque is what holds it together after the key has it in the right position. The key is an index, and isn't meant to carry much of any load.
    The right bolt torque is only after all the parts mating surfaces are OK - flat & smooth & lubed.
