Results 16 to 24 of 24
Thread: anyone tried atmo cams in a 1ggte??
    Junior Member Backyard Mechanic 1jzracing's Avatar
    Default Re: anyone tried atmo cams in a 1ggte??
    Quote Originally Posted by ekoston69
    ah ok soon to get a pair, was just gonna wack em in and tune it with the safc before i get the adjustable gears. Has anyone ever done a write up on changing camshafts in a 1g? Had a quick look and couldnt find much on it. Can anyone point me in the right direction?
    its pretty easy
    this order is critical
    take off front cover
    crack loose the cam pully bolts, take 10mm socket and extension poke it through the cam pully onto one if the bolts that holds the backing plate for the front cover and hold it square to stop them turning
    now set the crank to TDC, mark where the dizzy rotor is pointing
    little plastic cover down by the front pully, under it is the tensioner pully, its spring loaded so loosen the bolt and slide the pully over with a screwdriver and nip up the bolt again to loosen the cam belt
    slide the cam belt off the pullies and remove the pullies, front cover backing plate and cam covers
    undo cam bearing caps evenly to allow cam to slowly rise up on the valve springs
    done!
    reverse the process to install, use a good assembly lube, somewhere here is the torque settings for the pullies and bearing caps
    make sure the seals are right in and remember to set the little notch in the pullies at the top b4 installing the belt
    i usually put a little dab of sealer on the front cap either side of the seal
    make sure the belt is tight by turning the exhaust cam in a backwards direction with a spanner hold tension on it while you let the tensioner release on its spring and tighten the tensioner bolt, (I usually crank the engine a few times and redo this step to make sure the belt is settled)
    dont attempt it if you have no mechanical experience
    a fool remains undescovered untill he speaks!
    90 Millcrest st
    legend! Anyone know the part numbers on na cams?
    Dont you get overlap problems with the boost pushing the intake charge out the still open exhaust valves?? Or is that fixed with the adjustable gears/not enough boost&overlap to cause a problem?? Could be interesting to see what 3SGTE+3SGE cams+Garret BBearing turbo+Adaptronic would =
    If anyone wants a pair I have some sitting in an engine I'd be happy to let go for around $100. PM me if interested.
    Junior Member Backyard Mechanic slipway's Avatar
    brisbane
    so has any one had good results with this as my head is got a rattle noise(sumthing to do with cams or valves just wondering if it would be worth puting some in.
    slipway, check your valve springs for fatigue. That would be my first thought.
    brisbane
    cheers dude how would i do that just take the cam cover off and look for?
    Pull the springs out, and check the unsprung height of them, as well as the angle they sit on. If they are lopsided, or have shortened over time, they are fatigued, and should be replaced with new items.
    stunt dog Backyard Mechanic Esteban's Avatar
    wa
    Of course if you've gone to the trouble of pulling them out to check that, you might as well replace them too :-)
  1. [warning] TRD 272degree cams for 4age
    By progkamol in forum Tech and Conversions
    Last Post: 19-07-2006, 09:48 AM
  2. 88kw blue top cams --> 4agze : shim settings and clearances!
    Last Post: 12-07-2006, 03:08 PM
  3. 272deg Cams, Bigport GE, Stock Comp...Big Improvement!
    By craigy in forum Tech and Conversions
    Last Post: 07-04-2006, 03:00 PM
  4. Whats the diference between these 7m cams?
    Last Post: 18-01-2006, 03:15 PM
