Results 1 to 15 of 24
Thread: anyone tried atmo cams in a 1ggte??
    Junior Member Backyard Mechanic 1jzracing's Avatar
    Default anyone tried atmo cams in a 1ggte??
    the atmo cams for the 1gge have a bee's dick more lift and duration, has anyone tried them in a 1ggte turbo??
    are there any gains without using adjustable sprockets, im guessing there would be
    slightly different timing
    a fool remains undescovered untill he speaks!
    Default Re: anyone tried atmo cams in a 1ggte??
    talk too 6boost hes done it im pretty sure
    cheers steve,
    1ggte, 11.22 @122mph
    S.A
    I like the idea. Any form of extra lift / duration is an advantage when after hp.
    Like you say the cam timing from factory mabe the only difference. Adjustable cam gears will fix this.
    Do you have adjustable gears ?
    Id still wack em in regardless
    Have crossed the idea already.
    You have a pooftenth more lift and duration, but not a significant amount.
    Depends on the power your chasing.
    Facebook | LinkedIn
    i will have some running in a few weeks,
    my 1g atmo cams are at the shop being linished atm,
    will be running na cams and adjustable cam gears....so far proven 30rwhp gains,...
    so yeah...there cheap, so why not,
    will be good to see how it goes on the dyno, hope to crack the 200rwkw mark still with afctory inj/ecu,
    keep us posted
    i dont have adjustable cam gears but do have some atmo cams
    will be interesting to see how far off 0 and in which direction they are moved to optimise the gains
    PS dont forget to zero the distributor and ignition timing every time you adjust the exhaust sprocket!
    vic
    well come and buy my front sump 1GGE for $150 and theres the cams , hehe
    Dave
    [QUOTE=1jzracing]keep us posted
    PS dont forget to zero the distributor and ignition timing every time you adjust the exhaust sprocket![/QUOTE]
    i didnt even think of that!!!....that would have been a stuuuupid mistake, lol
    i'll hopefully have it running in a week or so, but wont see a dyno for a few weeks, to have a tune,
    forcefed6, has also siad that it completey shifts the power/torque curve asell........but not sure if hes using NA cams..
    How much would one expect to pay for a set of atmo cams?
    Facebook | LinkedIn
    i got mine for $100.....
    i got mine with a bit or surface rust for $50 they cleaned up real good
    i stuck them in the other night only took a couple hours
    its funny it make more boost but feels like less power !!! .... go figour??
    well its shifted ther power around a little it seems to spool up about the same but sure doesnt have the surge of wheelspinning torque it used to when it hits full boost
    feels better off boost as would be expected
    i havnt re-tuned for them at all, it seams ok but i may be able to add a little timing or fuel here and there
    im sure with a little tuning and cam timing change it would be better than before
    90 Millcrest st
    were the adjustable cam gears necessary? Or did you just pop em in on the standard gears?
    you can use standard gears....but to get the most out of them you will need the cam adjustable cam gears.......
    forcefed6 makes and sells the adj gears on here, (check the forum sponsors thread)
    Quote Originally Posted by 1jzracing
    feel like it will rev easier, cleaner?...id get your name on the adj cam gear list, jamies just about to make another batch of them,.
    90 Millcrest st
    ah ok soon to get a pair, was just gonna wack em in and tune it with the safc before i get the adjustable gears. Has anyone ever done a write up on changing camshafts in a 1g? Had a quick look and couldnt find much on it. Can anyone point me in the right direction?
  1. [warning] TRD 272degree cams for 4age
    By progkamol in forum Tech and Conversions
    Last Post: 19-07-2006, 09:48 AM
  2. 88kw blue top cams --> 4agze : shim settings and clearances!
    Last Post: 12-07-2006, 03:08 PM
  3. 272deg Cams, Bigport GE, Stock Comp...Big Improvement!
    By craigy in forum Tech and Conversions
    Last Post: 07-04-2006, 03:00 PM
  4. Whats the diference between these 7m cams?
    Last Post: 18-01-2006, 03:15 PM
