Results 1 to 7 of 7
Thread: stoping coolant flow to ISCV....?
    Default stoping coolant flow to ISCV....?
    hey guys,.
    with the new motor to go in soon,
    i want to keep it simple, no heater core, no flow to the manifold/iscv,....
    so what i want to do is blank of the rear plate on the 1g, and blank off all external coolant line's.....
    will i have trouble with the idle speed? will it run?....
    i figure it will be harder to start...tthat desnt bother me...
    Default Re: stoping coolant flow to ISCV....?
    Are you running standard ecu? If so im pretty sure it will just try and idle at hot temp speed.
    You may need to warm it up with your right leg.
    yeah will be stock ecu for a few more months.....
    thats what i was thinking, would need to keep foot on the gas for a fe mins....
    Deal with the Frog Backyard Mechanic Cool1's Avatar
    Just connect your AC idle up valve to a switch on ya dash. Flick the switch on cold mornings to bring the revs up until warm
    With my microtech, we have the idle up plated off on the 4age. Idles at 1200 rpm and gets hot enough pretty quickly.
    6 wire ISCV's dont monitor coolant temp.
    The coolant is purely there to stop it from freezing solid in cold cold climates.
    Your ecu wont even know you removed it.
    awsum, + rep coming your ways, if i can,,,,lol
    i just want to keep the cooling sys, as simple as possible, block/head/rad!
    cheers guys,
    blake
  1. 2JZGTE Engine Coolant Capacity? Aristo...or Supra
    By sbyder in forum Tech and Conversions
    Last Post: 08-03-2007, 08:08 PM
  2. 7MGTE ISCV Dilemma
    Last Post: 05-10-2006, 08:19 PM
  3. Aftermarket engine management and injectors
    By benjamin in forum Tech and Conversions
    Last Post: 14-05-2006, 02:05 PM
  4. Head flow thread, please post for all to see
    By Mr DOHC in forum Tech and Conversions
    Last Post: 19-01-2006, 06:41 PM
