Results 1 to 4 of 4
Thread: ARP rod bolts into 6m
    Junior Member Backyard Mechanic pete05's Avatar
    penrith nsw
    Default ARP rod bolts into 6m
    can some one confirm if 7mgte ones will fit into the 6m?
    Default Re: ARP rod bolts into 6m
    go to the rocket industries site and look at the part numbers and see if they match up..
    JZA80 Convert Backyard Mechanic
    I imagine they would, 6m/7m bottom end is interchangable. But as above, check part numbers to be sure.
    queensland
    i recall there are 2 different lengths of bolts. email me at work if you want some, and I'll check stock & lengths. [email protected]
  1. Negative Rear Camber bolts for MA61/MZ10/MX73 !!
    By bbaacchhyy in forum Tech and Conversions
    Last Post: 03-08-2014, 09:12 PM
  2. Replacing head bolts with studs.
    By PHOBIA in forum Tech and Conversions
    Last Post: 17-09-2011, 11:36 AM
  3. 6M and 7M differences???
    By fatboy13 in forum Tech and Conversions
    Last Post: 10-01-2006, 07:20 PM
  4. Flywheel Bolts 1JZ-GTE R154
    By rogue-vl in forum Tech and Conversions
    Last Post: 26-12-2005, 06:05 PM
