Results 1 to 13 of 13
Thread: 1G hitting "boost cut" at light throttle
    Turboholic Grease Monkey VeeP's Avatar
    Default 1G hitting "boost cut" at light throttle
    hey all
    ok long time prob but i havent brought it up.
    my 1G soarer hits a cutout of some sort at between 50% - 95% throttle at around 4500rpm and iv got no idea what it is. The check engine light lights up then goes off for about 3 secs and the codes recon its got something to do with the AFM.
    thing is at full throttle it doesn't hit this cutout. . any clues?
    its only runnin about 15psi with the AFM tightened up, exhaust and a cooler
    '88 Soarer GT-L
    '90 Supra Aerotop
    Default Re: 1G hitting "boost cut" at light throttle
    Find another AFM and try it. tinkering with the AFM causes more trouble than good unless on a dyno....
    Failing that reset the AFM back to factory. I had similar issues when tinkering with mine.
    Simon
    Beige.... The new Black!!!
    1G beliver Backyard Mechanic BLK1g-gte's Avatar
    Its the AFM for sure, I just replaced mein cause it was doing a similar thing.. It was cutting boost at 11psi. My original AFM died and the spare one i had lying around has had the spring fiddled with. As soon as i got another one unopened and original everything is back to normal...
    just got my old AFM back on (unmodded) it now hits boost cut at 15psi or so. . around 6000rpm . . i assume this is the "real" boost cut yeah?
    so. . how do i dodge this now?
    '88 Soarer GT-L
    '90 Supra Aerotop
    tasmania
    Quote Originally Posted by VeeP
    um, if it's going good with no problems i'd suggest you don't "dodge" it.
    beer me!
    u neeed a boost cut defender....
    and factory boost cut is 15psi.....so its running fine.....
    You should not need to dodge. If you got standard turbos they are not much good past this anyway... The proper way to dodge it is to get a SAFC, lean out the mixture and it will raise the boost cut. You get more power from a better air/fuel mixture and raise the boost cut if your really wanted to. I would not go past 16psi on stock turbos.... there is no benefit to it....just my 2c
    . . . ok time to chuck my SAFC back in then huh.
    i meant dodge as in raise the factory fuel cut. . . not. . . be dodgy . . . nvm.
    iv had the std turbos up to 22psi. . . and. . there is absolutely no diffference between that and 15psi.
    ok ty ppl.
    btw wahts the agreed max output of a 1G with std turbos?
    '88 Soarer GT-L
    '90 Supra Aerotop
    It depends if its manual or auto...but max so far has been 193rwkw with the normal being around 160 to 170rwkw...
    Have a read here:
    http://toymods.net/forums/showthread.php?t=12903&page=8
    yo u deserve rep f00l
    '88 Soarer GT-L
    '90 Supra Aerotop
    CROSSPLANE CRANK! Domestic Engineer Merudo's Avatar
    Same here, I made less power on 21psi than I did on 15psi.
    I shit myself when I saw it go up to 21psi on the dyno - it was supposed to be a low boost run!
    bahaha . . .
    stupid toyotas turbos just take the abuse like a kid gettin picked on at school
    '88 Soarer GT-L
    '90 Supra Aerotop
    indeed they do...
    although like said kid getting picked on at school, they take it for ages and ages and then one day just snap and go postal
    or in the turbos case, lunch themselves
    heres hopin that doesnt happen to me until i dont need them anymore, though
  1. ECU error codes flashing through ABS light??
    By Alchemist in forum Tech and Conversions
    Last Post: 25-06-2006, 07:41 PM
  2. Replies: 24
    Last Post: 18-04-2006, 01:42 PM
  3. ST162 warning light?!?!
    By XiL3D in forum Tech and Conversions
    Last Post: 08-03-2006, 02:03 PM
