Results 16 to 30 of 32
Thread: MZ21 won't start! help us, we're stranded :(
    limmy 1st year Apprentice
    Jan 2007
    tasmainia
    Default Re: MZ21 won't start! help us, we're stranded :(
    yeah think its gunna be a direct line to power the starter with a switch in the cab, only realy way i can thinkof it, i wouldnt mind still trying to find the nuetral starter switch? its the only thing i can think of that would of buggered up, therefore not starting it in any gear at all. locaed behing the dash maybe? have to have a look
    Tasmania
    Quote Originally Posted by limmy
    Hi Liam,sorry to hear that the Soarers playin up at the moment.
    If your running the A340 auto then the neutral safety switch should be located on the side of the box where your shifter rod is.
    Cheers Brett.
    User Conversion King
    NWA
    the battery might have dropped a cell.
    it would appear there is 12v but the battery is no longer capable of delivering the current drawn by the starter.
    hello
    West Australia
    Does it even make the "tick" "tick" sound when u turn the key ?
    or does it just make no sound at all ?
    Jan 2007
    tasmainia
    it makes the tick tick sound as the relays are clicking when u turn the key. and no the battery hasnt dropped a cell, it turned over the starter easy so its not that, im wondering if the diagnosis will pick it up????
    Jan 2007
    tasmainia
    cheers brett
    Jan 2007
    tasmainia
    found out that it was the neutral switch on the gearbox that went, the plug is still ok so bridged that connection to bypass the switch, but now that car starts in any gear which is a little dodgy but it start which is the main thing i spose, gunna have to drop the gearbox out to replace it i think.
    Modify is my middle name Grease Monkey Darola's Avatar
    hey there mate, neutral start switches just bolt onto the side of the gearbox, easy thing to change....
    ed
    Eddie 0433 85 69 66
    Tasmania
    Great to hear that it is now goin Liam.If by chance the MX62 Cressida neutral switch is the same,I have one here if it will help
    Cheers Brett.
    Im still just a......... Backyard Mechanic NoRecall's Avatar
    Tasmania
    He he he...... My Cressy dose that!
    its shockin when you forget to put it in park when you turn it off... I cant see that being a prob though cause you'd want it in park or nutral to cool the turbo down whne you stop.
    Best of luck lim!
    From Tassie?
    tasmania
    Quote Originally Posted by crowncustom
    Cheers Brett.
    he's got a spare box, it was in the other soarer.
    beer me!
    Tasmania
    No probs then.That was a bonus he got the auto with the other car.
    Cheers Brett.
    Jan 2007
    tasmainia
    ahh cheers guys, good to know people who have my back with parts n stuff, great bus just a shame that bit failed on me two days after getting is regoed, joecool was with me, and after frigging for ages it was just hopeless in the dark. i guess the next thing is trying to keep the bloody thing cool. its just not getting enough cold air, im gunna have to cut a hole in the front of it and make a air box. dunno need some better way of cooling it, everything is such a tight fit in the engine bay.
    Tasmania
    Is it hot as in water or under bonnet temp.If its under bonnet temp then it is a typical M engine.The Cressy gets very hot under the bonnet.I know the old Crown wagon used to do the same also and most M powered beasts I've come across do the same.
    Cheers Brett.
    Western Aus
    the air intake is fine, with a stock airbox its tops, howevere with a pod its actually worse.
    make a box for it to keep all the engine bay heat out.
    as for the under bonnet heat, as has been said, 7M's run REALLY REALLY hot normally, nothing to be concerned about as long as you know the water system is all good, and wont bugger up causing the temp to skyrocket.
    7M love.
    Elmo.
  1. 4age wont start, distributor?
    By carsanactra in forum Tech and Conversions
    Last Post: 25-01-2007, 05:29 PM
  2. 4agze hard to start and then stalls
    By wiso in forum Tech and Conversions
    Last Post: 07-12-2006, 11:31 PM
  3. DIY alram install (auto start), for n00bs
    By PlacentaJuan in forum Tech and Conversions
    Last Post: 29-06-2006, 03:19 PM
  4. 3SGTE Hard to start
    By SilverGhost in forum Tech and Conversions
    Last Post: 27-01-2006, 11:16 AM
  5. car won't start
    Last Post: 17-01-2006, 08:13 AM
