Results 1 to 7 of 7
Thread: RA60 dash prob with 1ggte
    Default RA60 dash prob with 1ggte
    Hi there, put 1ggte into ra60, goes like a b***h but would like to keep tcho standard..in dash does the 1g generate a different pu;lse profile and if so wich...while while we r at it is there a cure for the w58 to standard speedo fix? any help would be appreciated
    Default Re: RA60 dash prob with 1ggte
    gearbox drive gear ratios can be changed to make speedo read correct search on here.
    and there are tacho adjusters you can buy and or make to fix the pulses. some tachos have an adjuster inside the casing on the circuit .. again search tech for more details.
    Black Betty >HERE!<
    (\__/)
    prob is it was an auto g/box now a 58... so what do I search for? I think I need pulse type?
    Black Betty >HERE!<
    (\__/)
    Tacho electric need pulse type i think? and speedo cable... thanx man
    if you have cable type you need to change the gears that the cable screws into in your w58 to the closest ratio to suit wheels etc as explained in the 1st thread.
    for the tacho open yours up .. if there is a little trim pot (dial thingy) you maybe able to adjust it to read right ... use a monster tacho etc to match your standard one to read right then remove the monster.
    thats my plan of attack any hoo
    Black Betty >HERE!<
    (\__/)
    Sounds like the way to go...many thanx dude!
  1. intercooler fit 1ggte into ra60
    By turmite in forum Tech and Conversions
    Last Post: 12-12-2006, 08:55 PM
  2. 1GGTE RA60 Conversion
    By RA60 KID in forum Tech and Conversions
    Last Post: 12-11-2006, 07:24 PM
