Page 2 of 6 FirstFirst 1234 ... LastLast
Results 16 to 30 of 77
Thread: Calling All 20v 4age Experts........
    Default Re: Calling All 20v 4age Experts........
    My mates 1jz had a few cuts in the exhaust after the turbos about 1/2 foot away and it made it run like a dog. Once he welded the slits up it fixed his problem. Similar to your scenario, high idle, no power, lower limiter also iirc.
    - LeeRoy
    i wired at 20v with no o2 sensor yesterday it went ok
    who wired it up
    are they experts or dumb idiots hehe
    have u checked cam timing
    have u checked static timing
    did the engine get things like water pump replaced and they fukt the cam timing up
    check comprtession
    if compression is ok then it must be electrical
    they are very basic to find faults on
    is air flow meter voltage of
    does it blow black smoke when u give it sum
    do the basic checks for mechanical probs then look at electrical
    try yr ecu in another car to see if its the ecu
    vic
    Sideshow.
    Me and my Brother made the loom, I'm no expert but he knows exactly what he's doing. We've checked and double chcked everything you mentioned, execpt the ecu itself. I havn't checked the compression since the engine's been in the car, but it was ok then so it would be ok now. I'll check it again anyway.
    I appreciate all the help guys.
    cheers,
    Dave
    vic
    Ok, My ignition timing is at 10 degrees and my cam timing is spot on. still no progress
    ok but the problem you have could be many things
    what code did u get this
    its so bloody hard diagnosing stuff on the net by saying its in imp mode
    loss of power coul dbe causeb by a million things
    did u change timing belt and is it right
    have u checked mechanical stuff too like compression
    but i have had to fix afew 20v wiring loms cause of dumb fucks
    thats y i try buy a spare 20v ecu at good prices and sell them for much more hehehehehe
    cause they fuk up abit
    vic
    YES, I have checked, double checked and triple checked everything there is to check. I am no "dumb fuck". I realise that it's hard to help somone through a forum, but this is the only place i know of filled with corolla enthusiasts. I will figure it out somehow.
    If anyone can direct me to someone in victoria who could help me find the fault or faults, I would greatly appreciate it.
    Dave
    alot of cranky people on these forums heheheheehe
    well get a bloody multimeter out and start probing
    if you cannot get codes out of the ecu then it makes the job 500% harder
    can you get the ecu light to flash constantly like there is no probs
    if you cannot get ecu light to flash at all then its prob the ecu
    Is it running the factory intake (incl afm and airbox) and exhaust?
    What about vacuum lines, is everything connected properly? What about a split vacuum hose, that will cause problems, esp high idle and poor running, and can be damn hard to spot.
    Toymods Club Member
    vic
    Quote Originally Posted by -GT-
    Yes factory afm but currently with no airbox. Genuine toyota sports exhaust, it's slightly larger than standard twincam ae82 exhaust. Every vacuum hose is connected properly and as of yet I've found no split hoses
    Canada
    As sideshow said, what are the diag codes.
    vic
    Quote Originally Posted by 3sgte
    The only code I'm recieving is 21, for the o2 sensor. I'm sure this would not effect the engine power. It is only used for cruising
    Yep, i ran without an oxy sensor for ages, it spat that code whenever you asked it but it ran happy the whole time; not your problem.
    If the ecu isn't suggesting a problem i'm thinking its mechanical. I'm leaning back towards intake reversion screwing with the afm, or unmetered air getting into the engine. What's on the front of your afm if no airbox? Pod?
    Might have to go through the vacuum lines again
    Toymods Club Member
    vic
    At the moment I don't have an airbox at all, I know that it's kind of dangerous that's why I've only been test driving it up and down the road. An airbox could not possibly effect the power though,... could it?
    No, but it could possibly smooth the airflow going through the afm. I have heard of open afm's jumping around and giving 'undamped' (for want of a better description) readings to the ecu.
    But i've also seen an SC12 powered pug 205 gti charging round wakefield at one of our days with the bare afm hanging out the front of the chopped radiator support...
    Put the airbox on and try it, at the very least you'll rule out one possibility.
    Toymods Club Member
    vic
    I'll have to get one first. Thanks
    Last Post: 17-06-2008, 09:53 PM
  2. 4AGE 86KW TVIS V 100KW 4AGE + Shocks
    By GeeEss in forum Tech and Conversions
    Last Post: 17-01-2007, 09:51 PM
  3. 20v 4AGE into AE92
    By dale_8888 in forum Tech and Conversions
    Last Post: 16-12-2005, 05:51 PM
