Results 16 to 30 of 39
Thread: Paint to use on bare block?
    Default Re: Paint to use on bare block?
    And are welsh plugs readily available? Reason I ask, is I'm gonna have to replace mine I'd say when I get the 1g block 'done'..
    Facebook | LinkedIn
    yes, any parts shop will sell them quite cheaply
    My KE25 thread
    I did this a while ago: http://www.toymods.net/forums/showthread.php?t=2465
    1st use a water based rust converter/primer. If any surface rust is starting, it will stop it going any further under your paint. Its a light green substance you just brush on, and when it dries where-ever there was rust starting will go black. Make sure you use plenty of wax and grease remover on the block first, and then a very light coat with some water (as per the instructions on the bottle). You can get the stuff in K&H brand or Septone, both work as well as each other IMO. Rodger suggested I do this, his paint has lasted MANY years on his block.
    Then once the primer has dried you can spray on your engine paint!
    I painted my engine well over 10 months ago and it hasnt cracked yet!
    Toyota Car Club (Qld)
    VHT for the win, 7 years and the paint was still great on the engine block.
    My KE25 thread
    Yeah by the way mine was VHT too, I also recommend it
    Quote Originally Posted by BigWorm
    With any luck, none! Although he does get to admire the gold sump when performing oil changes.
    Yep, you'd never know that the engine is bling, can't see shit captian
    Biggest waste of time ever (bar oil changes...)
    Oh and to the goose that said I didn't paint the inlet manifold...I didn't want to.... I've got a spare one that is still in the polishing process
    Atleast you didn't paint your rear subframe as well
    If in doubt power out
    But have you run it through a car wash 52 times, and does the water still bead?
    Quote Originally Posted by SL666
    Yeah and I fried an egg on it for good measure
    My KE25 thread
    User Conversion King
    NWA
    my vote has to go to plain old "shop enamel" from your local paint supplier.
    infact enamel is good for everything. ive painted 2 cars with it and many engines,gearboxes, diffs, trim pieces (black plastic on bumpers etc)
    cheap too. about $45 for 4 litres. when you compare it to the cheap shit at super-crap-auto it even better value for money. there is more paint/dollar
    very glossy and doesnt fade that quick. resistant to fuel/thinners. you can paint it onto a unprepped surface and it will still last forever!
    hello
    Write English! Grease Monkey GasedT18's Avatar
    A good tip for blocking up all the threaded bolt holes on the block (you'll obviously mask up the top of the block & install your welsh plugs) is a whole bunch of earplugs, particularily if you can get them free from work. Just like installing them in your ears you roll them up to compress them, stick them in the holes & they'll expand & form a nice tight plug that is easy to remove once painted.
    Good one. I've used hot melt sticks - they come in a few diameters and can be softened crammed in and choped off flush with a blade. I wouldn't be putting silicone rubber around welsh plugs a good metal to metal seal is needed.
    sillycar chick - my initial thought - that's a lot of nail polish! The stuff that turns iron black is Phosphoric Acid - available in many of the rust converters but it can get sticky if you don't wash it off quickly.
    Goose indeed - ha, what cheek! Are you sure you're not polishing something else there Wilbo?
    T-18 SE series 2 1982 3T-C dual fuel, now under resto
    3T-GTE rebuild with fancy gas bits under consideration
    AE71 CSX 1984 auto
    Parts Wanted ASAP - See Parts Wanted
    tasmania
    try not to touch the bare metal, the perspiration on your hands will cause it to rust. not straight away, but it'll be the starting point. the quicker you get paint on it the better.
    beer me!
    what about the rocker covers, would anyone use the VHT egine can's or go 2pack? Not sure the can's get that nice gloss finish.
    W.A.
    im not going to guaratee that it will last forever....although it lasted 2 years on my 18rg.
    I stripped back the block and painted it metallic purple and then clear coated it. I used normal acrylic car paint. Boy was it fukn glossy
    Every1 said it wouldnt last as soon as it got hot.....2 years later it was still going strong.
    As i said i wont guarantee it......but hey worth a try and it paid off
    Matty
    AGE-16V Automotive Encyclopaedia Dimmy's Avatar
    Painted my block today, turned out awesome and for $8/can it was even better Used VHT "flat black" i think it was called and 288degrees resistant
    I have been pruned by old man river!!!!!
  1. Respray tips
    By Shifty in forum Tech and Conversions
    Last Post: 05-06-2006, 05:13 AM
  2. Guide: Removing paint from plastic parts (more input needed)
    Last Post: 13-04-2006, 02:09 PM
