Page 1 of 3 123 LastLast
Results 1 to 15 of 39
Thread: Paint to use on bare block?
    Default Paint to use on bare block?
    Hi all,
    Ok I have just got my block back from the machine shop and it is now time to add some paint to the outside before it begins to rust...
    Now my questions is what is the best type of paint to use that will last the miles? Is any heat proof pressure pack going to do the job??
    Junior Member Backyard Mechanic STR8 2.8's Avatar
    Default Re: Paint to use on bare block?
    just get engine enamel. lasts forever. any auto shop will have it. vht stuff is the goods
    I have a Crown
    yep I vote VHT.
    <shameless plug >
    I suggest 'poo' colour
    Junior Member Domestic Engineer psychofox's Avatar
    yeah you can pick up engine enamel from Auto Shops or even places like Bunnings, etc. I would paint it black, that way you won't see the oil leaks!!!
    Wollongong Sporting Car Club - Secretary
    Current Cars:
    2004 TW Magna VR-X AWD w/6G74 - Tow Car
    1989 AW11 MR2 w/4A-GE 20V - Track Car
    Write English! Grease Monkey GasedT18's Avatar
    Pretty, pretty wilbo666,
    but you didn't do the inlet manifold to match!!!
    TheDarkRaver, are they o-ring grooves or very thick sleeves? Know nothing about that engine.
    I heard somewhere in the racing engine building scene that some people paint the inside of the engines to help stop the oil sticking or getting contaminated or something WTF!
    Forget the paint job - polish it up and get it gold plated
    The only thing I've painted on an engine is a sump and used engine enamel from a can - can't remember the brand but it cracked
    What machining did you have done and how much did it cost?
    D
    T-18 SE series 2 1982 3T-C dual fuel, now under resto
    3T-GTE rebuild with fancy gas bits under consideration
    AE71 CSX 1984 auto
    Parts Wanted ASAP - See Parts Wanted
    Permanent paint? POR 15 chassis black
    Ok thanks guys it looks like im off to the local auto shop to get a few cans tomorrow..
    Yeh they are o-rings, I got the blocked bored .5mm to fit a set of forged pistons in, the crank rods etc balanced, new little ends pressed in and a few other little bits n peices.. Now the fun part of putting it all together..
    A good tip for blocking up all the threaded bolt holes on the block (you'll obviously mask up the top of the block & install your welsh plugs) is a whole bunch of earplugs, particularily if you can get them free from work. Just like installing them in your ears you roll them up to compress them, stick them in the holes & they'll expand & form a nice tight plug that is easy to remove once painted.
    They give very nice results.
    I've used Killrust in the past with good success.
    www.billzilla.org
    Toymods founding member #3
    Matt black FTW
    How the hell do you get the welsh plugs back in?
    Facebook | LinkedIn
    Use a large socket that fits snuggly, and tap it in, making sure it goes in flat and even.
    Just like we say in the aircraft maintenance industry, if at first you don't succeed, get a bigger hammer!
    Hammer & a block of wood to get it in straight, and if you're really keen a light smear of silastic around the edge before insertion.
    yep I vote VHT.
    <shameless plug >
    And Wilbo, how much of that is visible?
    Quote Originally Posted by JustCallMeOrlando
    With any luck, none! Although he does get to admire the gold sump when performing oil changes.
  1. Respray tips
    By Shifty in forum Tech and Conversions
    Last Post: 05-06-2006, 04:13 AM
  2. Guide: Removing paint from plastic parts (more input needed)
    Last Post: 13-04-2006, 01:09 PM
