Results 16 to 30 of 60
Thread: Chinese Turbos .... ANY GOOD ????
    Default Re: Chinese Turbos .... ANY GOOD ????
    it is just an internal gate. Just weld it up and pretend it is supposed to be an externally gated turbo. That is what I did.
    I would love to get a garrett turbo but can't afford it so el cheapo it is. It is going well so far and I plan on this thing pushing me into the 11's soon enough.
    edit: running 15psi so far and it has spiked to about 23psi once (accidentally). I don't plan on running big boost as I will be using nitrous. Hypergear recommend 20psi or less. That is probably because of the warranty I would say. You can't really expect a turbo to live forever if you are pushing BIG boost.
    QUICKEST 1JZ'S IN OZ
    Hm, im tempted to play with one on the side of a 4AG. 25psi though....
    has no Toyota anymore :( Conversion King tooch's Avatar
    Have a look into the Holset turbo's as well. They have been used pretty successfully by some guys in the US on MR2's and such. They aren't a 'chinese' brand either, they make truck turbo's.
    Nay sayer Domestic Engineer Mr Ed's Avatar
    May 2006
    Ive been thinking about a twin KKR setup on my 2J for a little while.........there is nothing between the 330 and the 430 though. 2x 330s arent big enough and 2x 430 is too much. Will likely run the twin 430s on medium boost but unless Im planning to use the turbo to its full power potential Im worried I'll be setting myself up for an unwarrented amount of lag.
    Something around the 380 size would be perfect for my goals.
    I used to eat alot of natural foods. That was until I learned that most people died of natural causes.
    The one on my friends hilux is running ~19psi now (or thereabouts). I drove it for a bit before xmas on 15psi and it felt quite good to drive. Now on the higher boost it's pulling distance on another friends car that run mid 12's - so it goes alright for a work ute .
    The hilux just makes use of the internal gate and doesn't have any boost control issues either (none that I noticed driving it and none showed up on the dyno). It's using a turbo smart dual stage controller.
    Shortly it'll be getting fitted with a 1J and a larger KKR turbo (the 430 I think it is) both of which are sitting in the garage just waiting for the available time to fit them.
    If my garrett dies I'll be giving a KKR a go on my 4A.
    My KE25 thread
    There is a 380 on the website
    My KE25 thread
    May 2006
    HOLYDUMBFUCK!!!! There is a god!!!
    Will check it out now! +rep for you!!!
    Are there any compressor maps around for the 330?
    Looks quite interesting.
    May 2006
    Actually after seeing the dyno charts for those LS1 kits, 2x KKR330 may be up to the task more than I first thought.
    New South Wales
    Quote Originally Posted by Sir_2jza70
    The designer of the LS1 kits is making over 400kW at the tyres on 11psi boost using twin 380s. I guess it depends on how much power you want to make, but I'd be expecting twin 330s on a 2J to be making anywhere from 300-350kW at the tyes on less than 20psi for sure.
    as far as boost goes, my CA18 with a 330 on it runs 16-17psi and makes around 206kW at the wheels. We have run it up to 19psi on the dyno without any dramas at all, although we backed it off to 16psi again as the engine didn't sound as though it was liking it!
    As for compressor maps, nothing is available at this time.
    Ah thats ok, ill probably give on a go on the road car before going to the GT28RS on the race car if i feel its warranted.
    CROSSPLANE CRANK! Domestic Engineer Merudo's Avatar
    Quote Originally Posted by Otomoto
    So even at 19psi that little turbo doesn't seem to be out of its efficiency range? or is around 20 pound that on the CA the 330 starts to run out of puff?
    From what i have read today the KKR330 has similar characteristics to the GT28 which means that it could handle about 25psi without struggling too much.
    Quote Originally Posted by deviant
    I still think the latter is better though...imagine the state the country would be in if no-one had jobs...
    We would be holding them off with rifles in trenches.
    Toyota Corolla Conquest 2003 black manual 1ZZ-FE - Daily
    Toyota Soarer GT-TL 1991 white auto 1JZ-GTE - [email protected] 1.587 60'
    My JZZ30 SOARER
    May 2006
    If an LS1 can make 380rwkw on only 10psi, Im hoping to be able to get similar power out of the same turbos on a 2JZ with higher boost (20psi?? maybe 22??)
    My goal is a reasonably responsive 500rwhp (~375rwkw) possibly with water/meth injection if needed.
  1. Does Anyone Have Two 1GGTE Turbo's
    By RA60 KID in forum Tech and Conversions
    Last Post: 28-06-2006, 01:47 AM
  2. MCCR cruise - good friday appeal!
    By Classique71 in forum Victorian Events
    Last Post: 18-04-2006, 06:22 PM
