Results 61 to 70 of 70
Thread: 1G Turbo Tech
  1. #61
    Nov 2007
    Default Re: 1G Turbo Tech
    Ah thanks, but same Internal Diameter?
    Remember that the pipes have 2 different ID's, The pipe begins round and then flattens like a rectangular shape. are both internal area's the same on Gen 2 and Gen 3?
    Thanks.
  2. #62
    Quote Originally Posted by Z2TT
    Thanks.
    Dude,
    Check post #10 and post #2 in this thread.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
  3. #63
    1G beliver Backyard Mechanic BLK1g-gte's Avatar
    Hey peoples
    Well i thought you be interested in this so i thought i post. After much discussion i have decided to keep my stock twin set up but add a twist. I currently Have Blitz BAG Turbos and was after an upgrade so decided to High Flo the already high flowed blitz. Due to the Bigger compressor housing after splitting them me and the guy who is doing the job decided to machine them and fit 1JZ Compressor and Exhaust Wheel. Well i put some pictures up and keep you updated on the progress and results.. We not sure not sure how it will turn out as nobody has done this yet....yes i am the guinea pig...
    The compressor Housing
    The Exaust housing. Here you can see the machining that has been performed to make the fit.
    Turbo dummy installed...just to see how it fits
    And most important
    The diffrence in compressor housing., Here you can see the smaller Stock CT12 vs The 1JZ Hi flowed Blitz
  4. #64
    Awesome.
    Looking forward to seeing how it goes.
  5. #65
    Hey Rod
    Yeah i am really looking forward to the result but have no idea what to expect. This was only possible due to the Blitz Bag Housing being bigger so there was enough material to machine. You could not fit the 1jz internals in a standard CT12. We estimate at least a 20% increase and boost efficiency to a bit over 20psi but hopefully due to the bigger Compressor wheel and exhaust we will reach the target without the need to go over 20psi. Hoping with the cams and all the other mods including the Microtech to reach power levels between 240rwkw to 260rwkw but its anyone’s guess now. I just like the fact that it’s something that has not been attempted so i will keep u guys posted....
    Now I just need to put the car on the diet which I am looking into…need it down to 1350kg…fun times ahead for the lil 1G
  6. #66
    Nov 2007
    Quote Originally Posted by TheToyman75
    Dude,
    I had a look, but those are the comparisons of the Feed pipes, not the outlet pipes.
    Thanks
  7. #67
    Ahh your talking about the bananas. I think they are the same but I honestly never checked....
  8. #68
    Thanks
    Maybe you missed this bit of post #2 ??
    "All of the exhaust housings share the same casting number and appear to be identical"
    The only "outlet" pipes the turbo's have is the dump pipe which is identical on all the stock Turbo's. Do you mean the Turbo Manifolds themselves ?
  9. #69
    Nov 2007
    Hi Rod,
    Ah I should have been more descriptive, by outlet I mean the compressor outlet, the ones that say "Toyota" and "Intercooler", they are above the rocker covers.
    Thanks.
  10. #70
    All the same mate. Just the Turbo Compressor pipes difffer...
    Last Post: 11-10-2014, 12:02 AM
  2. Turbos 101
    Last Post: 24-01-2007, 07:23 PM
  3. 2TG Turbo Upgrade - Advice/help please
    Last Post: 22-01-2007, 10:12 PM
  4. 7m-gte turbo leaking, need help...
    By shaun185 in forum Tech and Conversions
    Last Post: 05-01-2007, 07:58 PM
