Page 7 of 7 FirstFirst ... 567
Results 91 to 96 of 96
Thread: 18RG rebuilds and power outputs?
  1. #91
    Junior Member Grease Monkey Gunna's Avatar
    tasmania
    Default Re: 18RG rebuilds and power outputs?
    Hey guys,
    Just wondering if anyone knows what size chokes and stuff i should use on 45mm webers with a worked 18RG? Any help would be great thanks...
    Cheers, Craig...
  2. #92
    2sc Breaker!!!! Backyard Mechanic bmxer54's Avatar
    Standard rebuild with sidedraught weber DCOE45
    It has 34mm chokes, f16 emulsion tubes, 165 main jets, f9 idle jets, 3.5 auxiliary venturis and 180 air correctors.
    It is making 78rwkw
    Peter
    My Rides:
    1x Brown St141 corona csx. powered by a gen 2 3sge, 1x RT142 turbo 1UZ, cd009 and G series, 1x Gj Sigma Scorpion injected and turbo'd, 1x KE30 2TG, w58 and F truetrac, 1x RT104 18RG, w58 and F truetrac
  3. #93
    Junior Member Backyard Mechanic egamirrorim's Avatar
    Cant believe I missed this thread during my research for my RG rebuild!
    K&N air filters
    Rebuilt & tuned 40mm solex's
    Minor port work done to the head
    After market valve springs
    Reground cams
    18RGU bored to 2058CC
    10.2:1 CR forged pistons
    All internals balanced
    Hurricane extractors & exhaust
    Standard distributor
    = 88RWKW which sounds pretty good compared to some similar spec'd engines in this thread.
  4. #94
    Jan 2012
    Finland
    Heh,not to rain on your parade but the 18R (yes,no-G) I made some years ago:92 mm flattops (cheap VW's),ported head with bigger intakes(maybe from MB),selfmade intake for 40 mm sidedrafts (32 mm chokes),stock cam and cast exhaust manifold,2" exhaust and stock ignition.132 hp and 213 Nm.Have the dyno sheet somewhere to check at what rpm but from memory about same as stock(quite natural considering the stock .. well,maybe it was 8R cam)
    Just to remind that some shitpile iron singlecam head can deliver ;-)
    Only for fun and to try what can be available cheap;no means max effort!
  5. #95
    Aug 2012
    Thats a really good outcome from a single cam!
    Mine
    40mm twin side draft webbers choked to 36mm (or 34mm need to confirm)
    30-70 Cam grind
    18r bottom end, Crank and block.
    18rgu pistons and rods
    18rgu head
    120hp on the dyno. The motor is still bedding in so after the next 1000-2000km I'll get another dyno and tune. (unless anyone thinks this is pointless)
  6. #96
    Nov 2007
    Finally got around to getting mine tuned today. 125hp and 117ft-lb. Not quite fully tuned as it popped the head gasket between 3 and 4 before final adjustments.
    RA28 (18RG)Members Ride
    RA40 (3TGTE)
    RA40 (18RC)
    SXA11R Rav4 Cruiser
    ACA33R Rav4 Cruiser
  1. Replies: 8
    Last Post: 24-09-2006, 08:47 AM
  2. Building an Australian RA21 (18RG + TA22)
    By ace in forum Tech and Conversions
    Last Post: 04-07-2006, 09:09 AM
  3. Computer Engine Modelling, (18rg in particular)
    By jeffro ra28 in forum Tech and Conversions
    Last Post: 08-01-2006, 10:20 PM
