Results 1 to 4 of 4
Thread: 20v o2 sensor
    T'ville, QLD
    Default 20v o2 sensor
    hi guys
    i have searched but couldnt seem to bring up anything usefull
    is the 20v o2 sensor a 3 or 4 wire and does anyone know of a suitable aftermarket replacement?
    thanks
    luke
    2T out 4A in....
    Default Re: 20v o2 sensor
    4-Wire heated O2 Sensor (Zirconium based voltage unit) to replace the 16V's single wire O2 ... 20V 4A-GE
    first google search , sourced from club4a
    http://www.club4ag.com/faq%20and%20t...ject%2020V.htm
    4 wire
    if you can find the ngk oxy sensor catalog you might find a replacement for an ae101
    4 wire sensor
    almost all will be fine.
    there are some differences in the resistance of the heating element, but not so much to worry (iirc, bosch has a lower heating current).
    the output should be the same from all the narrow band sensors, so as long as you can find one that fits, (or if it has a flange, get a flange made, or from exhaust shop), then it will be fine.
  1. ECU jzx100 pins
    By splatt in forum Tech and Conversions
    Last Post: 30-08-2011, 07:11 PM
  2. 1GGTE<->RA28 Project
    By DoctorDubb in forum Engine & Driveline Conversions
    Last Post: 21-07-2006, 02:34 PM
  3. MAP Sensor line placement
    By CrUZida in forum Tech and Conversions
    Last Post: 24-01-2006, 06:27 PM
  4. o2 sensor heaters
    Last Post: 17-01-2006, 07:16 AM
