Results 1 to 15 of 17
Thread: XD, XE, XF Falcon wheel offsets
    Bogan Hunter Grease Monkey
    Default XD, XE, XF Falcon wheel offsets
    Just chasing the offsets of the above Falcons.
    Figured there would be some Ford nuts among us that would know....
    Gabe
    Junior Member Backyard Mechanic Bazooka's Avatar
    May 2006
    Default Re: XD, XE, XF Falcon wheel offsets
    Dont know but try this site.
    www.xfalcon.com
    Montrose
    Generally around zero
    What are you looking at putting them on? I've used various Ford wheels on various Toyotas a few times and it's worked alright.
    Cheers Baz, that site looks like it hasn't been up for long.
    Not a lot of info on it yet.
    Cheers anyway....
    Gabe
    Just looking to see if the Simmons I have will scrub at all on a mates XE.
    I need to work it out on paper first though as I don't have access for a test fit.
    How much room under the guards for movement either way?
    I'm guessing a fair bit....?
    Montrose
    Hmmm, a little bit.. What size are the wheels?
    Rears are 17x9 with a 100mm backspace.
    Fronts are 17x7 with a 128mm backspace.
    Reckon they'll fit ok?
    Cheers....
    New Zealand
    Fronts will sit in further than factory, rear will sit further out. You sure those measurements are right? Would give you over 50mm difference in offset.
    Callum
    Definately sure on the measurements.
    They were built for my old AE86 that had a different diff and different front hubs, that's why the offsets are wierd.
    So they will fit, but not perfectly....?
    New Zealand
    Will depend on tyre width, but likely to hit outer guards on rear and rub suspension on the front.
    Callum
    Victoria, Mt Macedon
    Stock size for XD-EB(??) alloy wheels are 15 by 7 with +6 offset. Any tyre shop should be able to look it up to double check though.
    Hen
    I've got a book with listings for most cars at home, I'll try and remember to check when I get home
    Thanks guys, Wilbo, if you remember to look, that would be great cheers.
    Make my life a little easier....
    Gabe
    New Zealand
    Quote Originally Posted by Hen
    Hen
    Thats what is stamped on my brothers wheels, from his ED V8 which is supposed to be the same as earlier models right up to AU where it went to a more FWD type offset (around +35 or +40).
    Callum
    5.5" Wide 14" Dia +11
    5.5" Wide 14" Dia +6
    6" Wide 14" Dia +6
    5.5" Wide 15" Dia +11
    6.5" Wide 15" Dia +11
    6.5" Wide 15" Dia +6
    6.5" Wide 15" Dia +12
    7" Wide 15" +6
    7" Wide 16" +6
    Seems to be what I could see as coming out on XD, XE, XF! (Njoy Universal Tyre Fitment Guide, Issue 6).
    There are a zillion pages of ford falcon, but that should be most of em...
  1. Basic Steering Wheel Conversion
    By Andrew162 in forum Tech and Conversions
    Last Post: 23-11-2006, 10:43 PM
  2. Wheel offsets and spacers.
    By Big T in forum Tech and Conversions
    Last Post: 07-05-2006, 09:44 PM
  3. lexus wheel offsets?
    By SL666 in forum Tech and Conversions
    Last Post: 11-01-2006, 07:33 AM
