Results 1 to 6 of 6
Thread: Included valve angle on a head
    Default Included valve angle on a head
    Bit of a complex question, but basically, without having a head recast, just wanted to get people's thoughts on any way to have the included valve angle amended in the head of an overhead valve motor.
    Theoretically it would seem that the old guides would have to be weld filled and then the new guide retapped\machined and new stems and stem seals sourced. But the only concern would be the shim\bucket or follower arrangement for the valve opening - getting the spacing\angle right to ensure the cam lobe is still working to allow the full motion as per normal of the valve.
    What are your thoughts?
    st162
    Gen 3 3sge N/A - 146.3 front wheel hp (109fwkw ) -
    NOW 178HP @ Front Wheels - N/A Gen 3
    Soon to be hi-comp turbo'd....
    Default Re: Included valve angle on a head
    It can be done, but it is a major operation.
    You've got most of the basics covered there, but as I'm sure you know, things aren't ever that simple...
    Quote Originally Posted by trd3sg
    Way, way, way too hard for the benefit gained.
    www.billzilla.org
    Toymods founding member #3
    Better and easier to just change the port angle if you are wanting to align the valve with the ports.
    if hte original head was bucket over/under cam, you would also have to shift the cams and thus the front seals and thus the timing cover and to make matters more difficult, shift the cams in a way that maintains alignment with teeth on the timin belt...etc
    ditto for something that used followers...
    1853949.3 times easier to change the ports on the head... infact you could probably CNC a new head from billet alloy easier than what you want to do.
    One of last year's Race magazine issues had a good article about porting options - including re-alighing the port entry. PM Nero on Performance Forums for detains on back orders.
    queensland
    used to do this on very modified minis. shit of a job. basically as described
    Last Post: 29-02-2016, 12:30 PM
  2. 2tgue & 3tgtue info
    By chippa07 in forum Tech and Conversions
    Last Post: 06-01-2007, 08:29 PM
  3. 2TG valve guides
    Last Post: 24-10-2006, 11:43 AM
  4. Removing / Inspecting valve springs without removing the head - is it possible?
    Last Post: 16-06-2006, 02:58 AM
